Will this damage my Leica?
skinnfell
I am playing with the idea of getting a flash for my Monochrom. To test out if I like to use flash or not, I have an old Canon 430EX . I know it won't work in TTL mode, but I wonder, is there any chance of harm to the camera if I use a canon flash in M mode on my Leica?
It's only the oldest flashes which were entirely manual which presented a high voltage to the flash contacts.
If you're in any way concerned, get a voltmeter (you can buy from next to nothing at the likes of Home Depot, B&Q, Maplin or whoever) and measure the voltage between the centre contact and the side ground contact. Chances are it's less than 12v.
I have used SF20 Leica Flash using curly grey 1 meter Nikon SC-17? TTL cord - works perfectly (same contacts as Leica flash)
Possibly Nikon TTL may also work in TTL?
That is not à possibility.
The contact locations are the same so the cord will work with the SF20 but the signals are not the same so a Nikon TTL flash wil not work in TTL mode.
