Paul J Posted May 15, 2013 Share #21 Posted May 15, 2013 Advertisement (gone after registration) You're going to start having issues, like the kind you are worried about, by around ±40MP. Even then it's not a severe issue. If you only use 18MP pics in size, once you size a 40MP image down to 18MP it negates the effects anyway. You only see them when viewed at sizes that permit it. I hand hold a 60MP Blad quite regularly and while you have to be careful it's not an issue. Going from 18 to 24MP is not going to show much change except for a smaller amount of fine detail. Link to post Share on other sites More sharing options...
Advertisement Posted May 15, 2013 Posted May 15, 2013 Hi Paul J, Take a look here M240 too good to use?. I'm sure you'll find what you were looking for!
01af Posted May 15, 2013 Share #22 Posted May 15, 2013 You're going to start having issues, like the kind you are worried about, by around ±40 MP. No, you're not. Once again: the issue we're talking about here has nothing to do with the number of megapixels—be it four, or 40, or 400. Link to post Share on other sites More sharing options...
wattsy Posted May 15, 2013 Share #23 Posted May 15, 2013 the issue we're talking about here has nothing to do with the number of megapixels—be it four, or 40, or 400. Of course it does if the image files are being viewed at 100% on screen which is when the "issue" becomes most apparent. I agree that it is largely not relevant for equivalent enlargements. Link to post Share on other sites More sharing options...
Guest tanks Posted May 15, 2013 Share #24 Posted May 15, 2013 Assuming the premise of more pixels equalling more degradation of the image from camera shake is true, I wonder how the new Photoshop CC's camera shake fix feature would play into this. Link to post Share on other sites More sharing options...
3D-Kraft.com Posted May 15, 2013 Share #25 Posted May 15, 2013 I found no difference between a D800E and a X100 As they are different in weight (inertial mass) and balance, there may be different degrees of camera shake even if you view results at comparable magnification. More important when comparing to M9 is that you have more buffer when using higher ISO in order to reduce shutter times. Link to post Share on other sites More sharing options...
pop Posted May 16, 2013 Share #26 Posted May 16, 2013 I have removed a number of posts which tried to imitate the ten minute's argument sketch with some personal insults thrown in. I'm sorry if there was some bycatch, but not very much.May I remind forum members again to proceed here with decorum, please.The argument started with the observation that the number of pixels of the sensor did not directly contribute to image blur due to camera shake but magnified the visible effect because of the greater magnification at a zoom rate of 100%. Participants appeared to be in agreement except for the wording, it seems. Link to post Share on other sites More sharing options...
