Comparison of M9 and M240
Zenny
More with M240 first again....
  • Replies 164
  • Created
  • Last Reply
and M9;
again..... reality is nearer the daylight version of the M9.
I do not have any comparison shots of humans ...... and my partner is camera shy .......
but here are a couple of shots from indoors with very difficult mixed lighting and 2500-3200 iso on the M240.
first is Auto WB from the camera..... truly, truly awful
second is Auto WB in LR4...... just awful
third is using dropper on the white/grey silk blouse..... looks ok to me
Another trio ....... this time corrected for the pearls on the blouse sleeve as a neutral reference ...... this can be marginally improved more by dialling out a bit more red...... as in the last image .... but one face gets better and the other gets worse ... more a matter of preference really :rolleyes:
again the out of camera WB is terrible..... and LR marginally better.....
bearing in mind the use of make-up the skin tones look ok to me.....
I'm not sure how the M9 would fare in similar conditions.....
I will do some more static indoor shots under artificial lighting tonight...... and then that's me done.
The comparison novelty has now worn off ..... so please could Leica fix the M240 WB so I don't have to do this anymore.....:p
No. I'm too lazy and disorganised to do sensible things like that .....
I suppose for an indoor mixed light shoot like the one above it would be worthwhile ......
I will bear it in mind if Leica fail to sort out the WB issues on this camera :rolleyes:
Some indoor comparisons..... as above, note: M9 first this time....
as before .... auto.... daylight.... cloudy ..... shadow
M240 .....
With these things are a bit closer..... the actual correct balance is between M9 Auto and Daylight (4850) .... the M240 auto looks fine ... but in reality is still slightly warm ... but much closer than the outside shots ...
The next are the same at night with incandescent light ......
these are Auto WB followed by Tungsten.....
M9 first
M9....
now m240....
There are different settings again for tungsten:
M9 2600
M240 3050
Steve
You deserve some kind of a medal for this.
I'm ashamed to admit I've just been sorting it when it's wrong (not all the time). I'm still not convinced that there is a correct answer to AWB in mixed lighting, but I agree that the new M gets it wrong either way!
Time for Bed
all the best
Well thats enough......
The subject of camera calibration is very complicated .... a brief dip into the texts is quite bewildering with numerous conflicting factors that have to be juggled about ... and inevitably there are compromises and perfection is impossible.....
The same is true of white balance .... there are a number of auto algorithms that either average the overall image or search for a reference white point ..... or variations on either of these themes ...... none work perfectly with every situation.
Its been an interesting exercise looking into this .... it is far more complicated than it first seems..... and I am not really surprised that the M240 colour balance is not perfect in the initial firmware ...... and at the end of the day do you want what looks nice ..... or what is a true representation of the subject..... ??
I suspect... and hope .... that Leica will revise this based on feedback .... I assume they keep an eye on the forum ..... ;)
I must admit that is so very thorough. What little comparisons I have tried, pale in comparison to your in depth work. Bravo.
Now, as you suggest, let us do hope they (Leica) are watching, studying in depth and reading.
At the end of the day I want to be able to see a true representation of the subject that looks nice.
Well, how do you know all those things? :confused:
Well... Thats how such platforms work once a next-gen model is comming...
You also see this behaviour in other 'man-driven' forums for cars, tv's, etc. nothing to worry about ;)
Of course, except in absolutely controlled lighting situations there won't ever be a 'right' answer anyway - the different light temperatures between shade and light in any scene can vary wildly - our eyes make decisions we accept, but how is the camera to decide?
Anyway - you've done a grand job, and I think we all agree that, right or wrong, in most circumstances the M is too warm.
All the best
Hi Jono, I'm sure you've probably mentioned the warm color issue to Leica. Because you're a beta tester I'd assume they would have to at least give you a response on your suggestions. Is there a chance you could tell us if they agree with what has been mentioned and whether they are working on a fix at the moment?
All the best
Yes and digital colour almost always looks awful in these kind of indoor 'use the light as you find it' (lowish mixed temperature) photographs and the new M looks like it is carrying on that tradition.
