stump4545 Posted March 15, 2013 Share #1 Posted March 15, 2013 Advertisement (gone after registration) if the epson 4900 uses about 8ml of ink per spot to power clean 11 spots that's 88ml of ink so if a 220 ml cart cost $90 bucks does a power clean cost $36? just trying to get a handle on usage. thanks Link to post Share on other sites More sharing options...
Advertisement Posted March 15, 2013 Posted March 15, 2013 Hi stump4545, Take a look here epson 4900 power clean. I'm sure you'll find what you were looking for!
Jeff S Posted March 15, 2013 Share #2 Posted March 15, 2013 The power clean is only for last resort; normal head cleanings should suffice, particularly if one regularly runs the printer and does nozzle checks. In any case, the cartridges are 200ml, not 220. And one needs to also account for replacing the maintenance tanks (the 4900 has two), as these fill when running cleanings. For a much broader assessment of ink usage, see the section titled Printer Economics 101 in the linked article. I own the 3800, but lots of info is readily accessible by search. Jeff Link to post Share on other sites More sharing options...
stump4545 Posted March 15, 2013 Author Share #3 Posted March 15, 2013 Thanks for the link! Link to post Share on other sites More sharing options...
stump4545 Posted March 15, 2013 Author Share #4 Posted March 15, 2013 any good guesses on how much ml of ink is used in a regular cleaning on epson 4900? initial ink charging i know is about 25-30ml per cart. wasnt sure about regular and power clean consumption per cart. Link to post Share on other sites More sharing options...
peterbengtson Posted March 16, 2013 Share #5 Posted March 16, 2013 any good guesses on how much ml of ink is used in a regular cleaning on epson 4900? initial ink charging i know is about 25-30ml per cart. wasnt sure about regular and power clean consumption per cart. Remember that the initial charging does not "use" all that ink. It is filling the tubes to the printing heads so most of it will eventually used in printing your pictures. It only shows as used because the sensors are in the cartridge. Link to post Share on other sites More sharing options...
Jeff S Posted March 16, 2013 Share #6 Posted March 16, 2013 Try reading the link I already provided and you'll know why I can determine that for my 3800, but you can't for the 4900. But you shouldn't even need to do many cleanings if you follow the advice already given, and also mentioned in the same article. Jeff Link to post Share on other sites More sharing options...
