A miller Posted March 12, 2013 Share #1 Posted March 12, 2013 Advertisement (gone after registration) I am scanning a bunch of MF color negatives on my coolscan 9000 using Vuescan. I set the cropping at "auto." Then a preview. The framelines are invariably off, usually outside of the picture. when I reframe the line to be precisely inside the picture, the colors and brightness tend to change! then I try to tweak the color and brightness channels to restore the image. but I dont always succeed. Why to the colors and brightness change when I re-frame the image and what can I do to prevent this? thanks in advance. Adam Link to post Share on other sites More sharing options...
Advertisement Posted March 12, 2013 Posted March 12, 2013 Hi A miller, Take a look here Vuescan workflow question - cropping. I'm sure you'll find what you were looking for!
vikasmg Posted March 18, 2013 Share #2 Posted March 18, 2013 I use a Coolscan 5000 and Vuescan tends to reconfigure the options depending on the scanner, but for my scanner there is a separate setting for crop framing and to set a buffer zone around the sides for Vuescan to ignore when estimating the white balance and exposure. This allows you to get Vuescan to ignore the black border etc around a scanned slide image (I tend to scan a bit more than the actual image so that I don't loose any of the image due too alignment problems or if it needs when de-skewing later). I'm not sure exactly where the setting is because I'm using the office PC at home. Not sure if the 9000 allows this setting. Link to post Share on other sites More sharing options...
