AlanJW Posted March 26, 2007 Share #1 Â Posted March 26, 2007 Advertisement (gone after registration) My dealer has a Visoflex III and bellows that is enticing me. Understandably, he wants to sell them together. I am hoping that some of the knowledgeable people here can answer some dumb questions: Is the purpose of the bellows to substitute for all the various focusing mounts that have to used with the Visoflex? Can it be used to focus to infinity with a 75mm (CV)?, a 50mm ('cron)?. Is there some other advantage or disadvantage to the bellows vs. focusing mounts? Thanks Link to post Share on other sites More sharing options...
Advertisement Posted March 26, 2007 Posted March 26, 2007 Hi AlanJW, Take a look here Visoflex III/Bellows. I'm sure you'll find what you were looking for!
carstenw Posted March 26, 2007 Share #2 Â Posted March 26, 2007 You cannot focus to infinity with normal lenses. Most of the adapters are simply to fit the various lenses onto the Visoflex, some of them directly, some just the head. A few of the special macro lenses have focusing adapters, I think. The bellows does two things, as far as I can tell: if you move the rear screw, you are moving the whole assembly, which focuses. If you move the front screw, you are changing the enlarging factor. The bellows has a much larger distance to the camera, of course, which gains you some flexibility. Â What price is he asking? Make sure it is a Bellows II. Btw, if you don't want the bellows, there is any number of people around here who will take it off your hands. Link to post Share on other sites More sharing options...
tobey bilek Posted March 27, 2007 Share #3  Posted March 27, 2007 You would want the bellows in place of the SHORT focus mount if you need a greater focus range, ie get closser. The normal long focus mounts will not allow infinity focus with the viso.  65, 90 4.0- 90 2.8 -90 2.0-125 2.5-135 -200- 280 are the common lenses that can be used on a viso with the proper short focus mounts or lens heads +adapters on a bellows ( no focus mount).  50`s and 35`s can be used on bellows but only for close work. Enlarging lenses Focotars work well for for close work.  Good luck finding all the rings/adapters/short focus mounts required to make this all work. It was tough in 1980 when I obtained all mine  Visoflex I  Visit the link for details Link to post Share on other sites More sharing options...
luigi bertolotti Posted March 27, 2007 Share #4 Â Posted March 27, 2007 With the bellows, You cannot focus to infinity with lenses like 50 or 75; can focus to infinity, for instance, with "old" Leitz 135 lens heads (Hektor, Elmar, Tele Elmar, unscrewed from their focusing mount) , but this is not the reason you shall enjoy it: its real goal is macro use: with the proper adapters (lot of kinds, not difficult to find) you can mount lot of lenses and have excellent results in macro also at strong ratios : some results (with M8) have been posted in this forum. Much better is that is a Bellows type 2, with double rail: more versatile than Bellows I - single rail - for you can finely adjust focusing without modifying lens-focal plane distance. If Viso III is mechanically good, the viewer (prism, I suppose) clean, the Bellows fine (beware of tiny holes in leather...) that is an outfit TO BUY: for macro use, an add-on vertical magnifying viewer can be useful. Link to post Share on other sites More sharing options...
