wildlightphoto Posted February 10, 2013 Share #21 Posted February 10, 2013 Advertisement (gone after registration) For myself, I would find a rotating collar useful for my 100mm f2,8 Macro Apo Elmarit, 180mm f3.4 Apo Telyt, 80-200mm f4 Vario Elmar, 70-210 f4 Vario Elmar, and possibly for my 28mm f2.8 Super Angulon PC lenses. If a rotating collar works as smoothly as the one on the 280mm f/4 APO I'd find it very useful for my 60mm Macro-Elamrit-R, 90mm Summicron-R, 100mm APo and 180mm APO-Elmarit. Link to post Share on other sites More sharing options...
Advertisement Posted February 10, 2013 Posted February 10, 2013 Hi wildlightphoto, Take a look here Leica R to M adapter. I'm sure you'll find what you were looking for!
naturephoto1 Posted February 10, 2013 Share #22 Posted February 10, 2013 If a rotating collar works as smoothly as the one on the 280mm f/4 APO I'd find it very useful for my 60mm Macro-Elamrit-R, 90mm Summicron-R, 100mm APo and 180mm APO-Elmarit. Doug, I wouldn't argue with that. If I do decide to make the investment in the M240 I will probably also purchase the Really Right Stuff L Bracket and Grip when it is introduced. I would probably opt for this instead of the Leica Grips. However, if I found that I needed the features of the Leica Multfunction Grip, I might also invest in that. Rich Link to post Share on other sites More sharing options...
algrove Posted February 10, 2013 Share #23 Posted February 10, 2013 The RRS U grip/bracket that I use on my M9 is very useful. I am trying to figure out if RRS has something currently offered that will work on the new M. For now I just have their 6" base plate which I figure if mounted on the Multi-function grip will allow battery and SD card changes without dismounting the RRS plate. Trouble with that is there is no L feature at this point on mine for vertical shooting. I do notice it has 2 holes at one end, possibly for adapting an L bracket. Will have to check into that. I use the Leica STA-1 for rotating my Macro and 180/2.8 lenses. Wish they still made that. Link to post Share on other sites More sharing options...
naturephoto1 Posted February 10, 2013 Share #24 Posted February 10, 2013 The RRS U grip/bracket that I use on my M9 is very useful. I am trying to figure out if RRS has something currently offered that will work on the new M. For now I just have their 6" base plate which I figure if mounted on the Multi-function grip will allow battery and SD card changes without dismounting the RRS plate. Trouble with that is there is no L feature at this point on mine for vertical shooting. I do notice it has 2 holes at one end, possibly for adapting an L bracket. Will have to check into that. I use the Leica STA-1 for rotating my Macro and 180/2.8 lenses. Wish they still made that. Unfortunately the RRS website is not allowing us to access the specific L Bracket an Grips right now as for the M9. This is the link to the page for all of the components for the M9: Really Right Stuff - Item Listing I had had a conversation with the RRS staff in the past about the M240. They indicated that there would be an L bracket and Grip. But, they can't start the design until they are in possession of a camera body. Rich Link to post Share on other sites More sharing options...
dierk Posted February 10, 2013 Share #25 Posted February 10, 2013 just to throw some more pictures into the discussion Leica M9, Leica Macro-Elmarit-R 100/2.8 @algrove up to 70cm I measure the distance and below I just try and adjust the distance manually by moving the object into the focus area (... and wait for the M ) click for larger view dierk Link to post Share on other sites More sharing options...
k-hawinkler Posted February 10, 2013 Share #26 Posted February 10, 2013 Dierk, Could you please briefly explain the point(s) you are making? Thanks. Link to post Share on other sites More sharing options...
dierk Posted February 10, 2013 Share #27 Posted February 10, 2013 Advertisement (gone after registration) Dierk, Could you please briefly explain the point(s) you are making? Thanks. K-H. I am not sure, what you want to know ... or do you think, that I am OT with these pictures, as I am not using the coming new adapter? dierk Link to post Share on other sites More sharing options...
k-hawinkler Posted February 10, 2013 Share #28 Posted February 10, 2013 K-H.I am not sure, what you want to know ... or do you think, that I am OT with these pictures, as I am not using the coming new adapter? dierk Hi Dierk, OT not at all. Those OT areas are sometimes the best parts of a thread. No, I wondered from which distance you took the shot and what parameters you used? Until I get my M I would take those shots either with Visoflex and Bellows or an old 50 mm macro setup on the M9 or use Leica/Leitz lenses on a NEX or OMD. Also with adapter rings one can get pretty close. Thanks. Link to post Share on other sites More sharing options...
algrove Posted March 28, 2013 Share #29 Posted March 28, 2013 I also have the appropriate rotating Novoflex collar: Novoflex TRIPOD MOUNT FOR MFT ADAPTERS ASTAT-MFT B&H Photo Video The rotating collar allows rotating the camera and lens around in all orientations. But, the incorporated Arca Swiss Type QR plate will not work with the Really Right Stuff QR clamps. The plate for the Novoflex is too narrow. It will work with all of my screw type clamps that I have from Kirk Enterprises, ProMediaGear, and Markins as well as some much older Really Right Stuff, (and I believe older Wimberley clamp- this one I have not checked, but it should work). This is the Leica R lens to M adapter from Novoflex: Novoflex Lens Adapter Leica-R to Leica-M Body LEM/LER B&H Photo I am not sure if the lens Novoflex rotating collar that I have will fit the Novoflex Leica R lens to M adapter. Rich Rich-Could you kindly indicate the part number of your Novoflex rotating collar? I will get one to try on my Novoflex LEM/LER adapter. Thanks. Link to post Share on other sites More sharing options...
algrove Posted September 9, 2013 Share #30 Posted September 9, 2013 Just so everyone here knows the LEM/LER Novoflex adapters are now shipping with 6 bit coding for bringing up the list of R lenses on the new M. I will have one tomorrow. Link to post Share on other sites More sharing options...
naturephoto1 Posted September 9, 2013 Share #31 Posted September 9, 2013 Rich-Could you kindly indicate the part number of your Novoflex rotating collar? I will get one to try on my Novoflex LEM/LER adapter. Thanks. I just saw your post. I listed the part number above: ASTAT-MFT, but I do not believe that the part fits the Novoflex LEM/LER adapter. The rotating collar is for Novoflex Leica R to the M4/3 adapter and also fits the Novoflex Leica R to Fujifilm X adapter. Glad that you are receiving the Novoflex LEM/LER adapter tomorrow and they are now come with the 6 bit coding. Rich Link to post Share on other sites More sharing options...
algrove Posted September 10, 2013 Share #32 Posted September 10, 2013 I just saw your post. I listed the part number above: ASTAT-MFT, but I do not believe that the part fits the Novoflex LEM/LER adapter. The rotating collar is for Novoflex Leica R to the M4/3 adapter and also fits the Novoflex Leica R to Fujifilm X adapter. Glad that you are receiving the Novoflex LEM/LER adapter tomorrow and they are now come with the 6 bit coding. Rich Thanks Rich What a relief the LEM/LER now comes 6 bit coded. Who needs the Leica one now. I still marvel that after 355+ days they cannot get this part out the door, but they can introduce 2 new smaller cameras without a problem during that period of time. Sometimes I feel they are forgetting it's the M buyers who keep them going not the $700 camera buyers. Link to post Share on other sites More sharing options...
MarkP Posted September 14, 2013 Share #33 Posted September 14, 2013 ...Who needs the Leica one now. I still marvel that after 355+ days they cannot get this part out the door, but they can introduce 2 new smaller cameras without a problem during that period of time. Sometimes I feel they are forgetting it's the M buyers who keep them going not the $700 camera buyers. You mean the camera- and adapter-free R-solution :D/ Link to post Share on other sites More sharing options...
George Furst Posted September 14, 2013 Share #34 Posted September 14, 2013 I have an older R to M adapter number 22228/500934 with Leitz Wetzler Germany and a red L.C. on the collar. So I had to send my M (typ 240) back for a display problem and I thought that they could code this adapter at the same time. They replied that they could not code the adapter as it was not made by them. I was credilus as it had all those markings on it and then they say "it is not ours"! I was shocked until I realized that it must have been out sourced by Leica to Novoflex to make this model of the L to M adapter. It is very well built and with a correct code put on with a magic marker it brings up the R menu but I was hoping for a more permanent solution and had to give up. At least the camera never gave me the dreaded "No lens Attached" message that it did with the other Novoflex adapters. When this happens 'live view' is disabled! Link to post Share on other sites More sharing options...
algrove Posted September 16, 2013 Share #35 Posted September 16, 2013 Here's the Novoflex I just received this last week and it works right out of the box. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/194575-leica-r-to-m-adapter/?do=findComment&comment=2421947'>More sharing options...
mmx_2 Posted September 16, 2013 Share #36 Posted September 16, 2013 Mine looks the same but the white strip is much paler and it won't code:(. Will try and paint it a bit with marker pen:) Link to post Share on other sites More sharing options...
algrove Posted September 16, 2013 Share #37 Posted September 16, 2013 Mine looks the same but the white strip is much paler and it won't code:(. Will try and paint it a bit with marker pen:) Are you saying that after attaching the adapter (it can be done without lens attached fro simplicity) and the after you hit Menu and then look at the Lens Detection line that Manual is not showing up? If Manual shows up I then have to hit Set to bring up the R list of lenses. Link to post Share on other sites More sharing options...
mmx_2 Posted September 17, 2013 Share #38 Posted September 17, 2013 Are you saying that after attaching the adapter (it can be done without lens attached fro simplicity) and the after you hit Menu and then look at the Lens Detection line that Manual is not showing up? If Manual shows up I then have to hit Set to bring up the R list of lenses. No, it stays in automatically and the "r-menu" does not show up . Mine looks exactly like yours otherwise . Which firmware do you have? All my other lenses work with lens detection . Link to post Share on other sites More sharing options...
algrove Posted September 17, 2013 Share #39 Posted September 17, 2013 No, it stays in automatically and the "r-menu" does not show up . Mine looks exactly like yours otherwise . Which firmware do you have? All my other lenses work with lens detection . Try jiggling the adapter back and forth while camera on to see if it recognizes the adapter. Some have had success with doing this. Link to post Share on other sites More sharing options...
mmx_2 Posted September 18, 2013 Share #40 Posted September 18, 2013 Try jiggling the adapter back and forth while camera on to see if it recognizes the adapter. Some have had success with doing this. Thanks for the tip, but no luck:(, thinking about having it coded instead:( Link to post Share on other sites More sharing options...
