Summitar for close-up
philipus
Apologies for this, likely basic, question:
I have a Summitar, which I like a lot, and understand that later versions of the NOOKY-HESUM work with this lens provided the lens name is inscribed on the front.
But does the NOOKY-HESUM only work with screwmount bodies or can I use it, with my LTM-M adapter, on my Ms? If so, are there any restrictions in usage on the M, for instance focusing-wise?
Thanks in advance
Hello,
The NOOKY-HESUM can not be used with M mount body.
Even with LTM Leica IIIg, it's useless.
The "goggle" attached is designed for only earlier LTM.
Arnaud
Because the negative lenses on the NOOKY must match with the windows of the camera.
How it works ? you choose the reproduction ratio on the NOOKY and next you move, usualy the camera, until you get the 2 images in the range finder coinciding
Just for fun, when I first have received, some years ago, my NOOKY-HESUM, I wanted to use it with my M8 and the Summar 5 cm I love.
The set-up is only for fun and the results not great.
I used a Leica III with the setup and as "distance comparator" with the rangefinder on a tripod, then swapped for the M8 with M adaptor, keeping same setting on the lens. The M8's viewfinder is a bit blocked and not accurate.
Much trouble for "nothing", only unsharp pictures, even when closed the Summar to f:12.5.
