Fisheye for M9
Guest NEIL-D-WILLIAMS
No but the R one will work as will many others via adapters. I used an R 16mm on my M8 for a time - focus was easy with the fisheye dof and results were fine but obviously the corners weren't used on the M8. Not easy to figure out fov though!
I am thinking of getting it for the new M so focus picking should help
I don't quite see how focus peaking should help with the field of view. For a 16 mm full coverage fisheye the CV 15 viewfinder gives a decent approximation, for a circular 8 mm one it is simple: 180 degrees...
I think btw that focus peaking will not work anyway. the huge DOF will have it totally confused.
Japp what I was meant to have said was Liveview and EVF will help as you will be looking through the lens so no issue on framing
