486 IR Cut filter use
hunz
Do you leave yours on all the time or only when you seen noticeable magenta issues. I have tried several tests with and without and some in tungstan situations. The results are mixed. Some look better on, some off. Opinions, experiences? Thanks in advance :D
I have mine on *all* the time because it's not just color shifts we're talking about, it also has a sharpness dimension which Leica is not going to admit. I see a significant increase in contrast/sharpness when the filter is on. I just do not have enough filers to go around. Still waiting for my 2 free filters from the Germans.
thank you for your response Arthur. I find the IR CUT filter mucks up the white balance sometimes. do you experience this?
Well that's interesting. I find that the IR filters IMPROVE color auto white balance, especially in a high IR invirornment (incandesent)
Rex
Maybe if you are shooting JPEG, but I redo white balance routinely as a first step while developing those RAWs that are keepers, and if anything it is getting closer. Other reasons to install the filter and fuggedaboudit:
sharpness
no false colors
deeper shadows in b/w (pace Sean R)
accurate flash exposures
scott
I have exactly Rainer's problem if I don't use a filter when photographing room interiors that have an open gas fire with radiants. The radiants are a bright fuzzy purple color instead of orange/red. Even with the 486 filter there is sometimes a residual unsharp purple fringe, the filters still leak a small amount of IR.
Bob.
Hi,
well, heat means infrared rays. The magenta does not come from the electricity, but from the heat-rays. And the pictures show that the B+W 486 really works. I leave it on the lense all the time.
Rainer:
Sorry, I forgot to add the ":D". Hab' ich eine Witze gemacht.
Gruesse,
Craig
