Which meter reading seems correct?
SiMPLiFY
  • Replies 44
  • Created
  • Last Reply
Hello swamiji,
2 separate items:
When measuring w/ any range/viewfinder or bellow-M lens & an internal meter & comparing that reading to a hand held meter it is necessary to stop the lens down to a point where vignetting is no longer an issue (F5.6 or F8 w/ your Summilux) so there is a COMPARABLE situation when metering.
A built in meter on a RFDR does not compensate for vignetting the way cams do on an SLR w/ open aperture metering.
You need a level playing field or else the meter will correctly say you need additional exposure w/ the lens fully open in order to compensate for vignetting.
2d item: If you have a number of meters or only 1 meter the only way to determine which is correct is to measure against a standard light source. If you do not have access to a standard light source & you live where the air is reasdonably clear, the altitude is not that high, there is not a lot of snow on the ground & you are not near a large body of water w/ a large light colored open ground near the water then: The correct reading between 10;00 & 14:00 on a nice day is more or less F16 @ 1/ISO.
Your Master V has a little adjustment screw in the back for regulating this. You can also use this screw to "0" the meter.
Best Regards,
Michael
Michael
Your first point is very valid, and I think it's where I may find the answer. I tried both the Summilux-M asph 50 and the APO-Summicron 90 and found them similar.
In regards to your second point. The sunny 16 rule does not apply here as its overcast 360 days a year, and you can have a 5 f-stop difference with no change in shadow. That is why I use a second light meter to compare. Yes the needle is nicely at zero.
I have a small sekonic and m9 and a few iPhone meters. I usually carry my m9 with my m4. Think of the m4 as my mm. Anyway when I get a bit confused on lighting I pull out the m9 to meter and find it matches up with the sekonic. Sometimes I prefer shooting the m9 like the m4 and don't worry about m9 meter and the shots I believe are better
I am starting to wish there was a way to turn off the meter of the M9, like the MP. I like my hand held better, it's slightly less exposed, and the colors turn out better.
I have a Sekonic, and it's too big to fit in my pocket. It's great for manual flash, as I have the PocketWizard interface. Works great for studio.
