dritz Posted July 29, 2012 Share #1 Posted July 29, 2012 Advertisement (gone after registration) Did a shoot today where the 35mm was too constrained for what I really wanted to cover in the interior. For interiors I usually can get away with the 35mm S or Hasselblad 50mm CFi with the Leica-V adapter. Today I wish I had something wider. What are the plans for wide angle lenses for architectural work -- especially tilt/shift lenses. The 30mm is too pricey without offering something substantially important -- such as tilt/shift. Thank you. Link to post Share on other sites More sharing options...
Advertisement Posted July 29, 2012 Posted July 29, 2012 Hi dritz, Take a look here Lenses for architecture . I'm sure you'll find what you were looking for!
dfarkas Posted July 29, 2012 Share #2 Posted July 29, 2012 Did a shoot today where the 35mm was too constrained for what I really wanted to cover in the interior. For interiors I usually can get away with the 35mm S or Hasselblad 50mm CFi with the Leica-V adapter. Today I wish I had something wider. What are the plans for wide angle lenses for architectural work -- especially tilt/shift lenses. The 30mm is too pricey without offering something substantially important -- such as tilt/shift. Thank you. The 24mm f/3.5 is slated to be announced at Photokina, which should give you considerably more coverage. Up until now, Leica has been tight lipped about tilt shift options. Hopefully, we'll learn more at Photokina. David Link to post Share on other sites More sharing options...
