Hand-coded CV15
steich
Hello,
I just managed to hand-code my CV15. As there is no other 15mm lens, I just used the WATE code. Now the EXIF shows "18mm".
Yes, I am glad it worked at all- but wouldn´t it be nicer to have the "16mm"? How can I reach that?
Stefan
Hello,
Stefan
Can you post a photo please Stefan - showing the mount and the coding? I was not able to code mine since the mount is cut away where the marks need to go and I cannot find the alternative adaptor mount is not cut away in this manner.
Thanks!
Tim
Hello,
Stefan
You can't. The camera currently knows nothing about the selected focal length and the value of 18mm seems to be a stop-gap until V1.10. Then, we're expecting a menu item somewhere where you will dial in the focal length you have selected.
So, with a WATE on the M8, you will select the focal length, select the finder view on the Franken-Finder, making a quick mental adjustment for the crop factor (why couldn't they do a sticky to put on the FF for M8 users to overlay the standard focal lengths with the effective ones on the M8? 16-18-21-24-28 would become 12-14-16-18-21) and then select the focal length on the menu. What a palaver!
@mark
I don´t like that term "FrankenFinder". Better to say BKMO ("Boris Karloff Memorial Optics")...
@tashley
I´ll post photos later. I used an old Leitz adapter that has no cutout.
Stefan
@mark
@tashley
Stefan
If you can tell me where to get that adaptor I will give you the soul of my firstborn...
t
Guest Bernd Banken
t
OK here I am :D
"Please allow me to introduce myself
Im a man of wealth and taste
Ive been around for a long, long year
Stole many a mans soul and faith
And I was round when jesus christ
Had his moment of doubt and pain
Made damn sure that pilate
Washed his hands and sealed his fate
Pleased to meet you
Hope you guess my name:cool:
It seems that Leica/Solms has an small amount of adapters in their warehouse. Please contact them directly, it could be that your request will be solved.
Cheers
xxx
t
Tim,
I bought a Leitz 9cm adapter here (look under Leica M accessories), but pricey at $85. I coded it as a 21mm for use with both my CV 21 and CV 15.
http://www.collectiblecameras.com/catalog/index.html
Carl
OK here I am :D
Pleased to meet you
Cheers
xxx
Thanks to both Stefan and Bernd.
Bernd, that's a really good lyric - you should get someone to set it to music!
Tim
Tim,
Carl
Thanks Carl,
I think I tracked down a slightly cheaper one but, as a Leica owner, naturally I will follow your suggestion first ;-)
Tim
