Any advice Rodinal with Fomapan 100?
traveler_101
Anyone use Fomapan 100 classic film? I have shot a few rolls and am looking to develop them in Fomadon R09, a Rodinal clone. Never used Rodinal before . . .
1: 25 or 1:50?
Agitation procedure?
This document tells all.
http://www.freestylephoto.biz/pdf/Fomadon_R09_Datasheet.pdf
Here is a JPEG version of the information, just in case you have trouble with the PDF
http://www.digoliardi.net/Fomadon_R09_Datasheet.jpg
View at 100%
View at 100%
There is another data sheet out there, however, showing different dilutions and times: http://www.freestylephoto.biz/pdf/Fomadon_R09_Datasheet_(1%20to%2025%20or%201%20to%2050%20Dilution).pdf
6-7 minutes @ 1:40
versus
9 minutes @ 1:50 :eek:
Highlighted above is a typical Rodinal induced circle of confusion. You will find enough times and dilutions and agitation methods to take you twice around the block. So the best bet is to use the first one you come across and use that, then adjust the times depending on results. The advantage of this method is that you will then have your own Rodinal recipe to add to future debates.;)
Steve
