MF problem or I am getting old
JackLu123
I am in process of getting Leica..... I have been using CV 35/1.4 on my nex 5, I uploaded my pict to computer, the picture was not as focused as I tought...... I thought I had it while looking at nex 5 screen. Now I am a little worry about MF, maybe my vision is not as good as before.......
A trip to the eye doctor?
They detect common eye diseases in addition to checking vision, most all of which have no symptoms you can detect yourself at early stages.
Those viewfinders are just consumer grade stuff anyway. They may be ok for for pics mom takes of the kids, but a pro camera it is not.
You might get a young friend to focus for you and see if you get the same result. Do you have camera shake from low shutter speeds. Not holding it properly?
It may just be a lack of practice. I find that the rangefinder gives me far more accurate focussing than a manual focussing on an SLR, and so many AF shots were in focus but on the wrong point that my hit-rate is no worse than it ever was with an SLR.
The good thing about the rangefinder is that as long as you can see whether the lines line up in the centre patch, you will be in focus.
I'd agree that for my old eyes I can focus a rangefinder more consistly than I can an SLR now, even with f1.2 lenses on the SLR.
The CV 35 1.4 does have some focus shift, but on the NEX you would focus at set aperture, so the shift shouldn't be an issue.
I use mine a lot on the M9, and I bet you will do just fine with it.
Jack - If you are shooting that lens wide open on the NEX you may want to touch the screen to magnify the zone you want to focus on. Focus peaking has room for error at f 1.4 and close distances. I suspect you will get along just fine with a Leica.
I used my summicron asph 35 on an Olympus E-P2 for several months before getting the M9. The focus on the E-P2 using either the screen or electronic viewfinder was much more difficult for me than the M9. Magnifying the image on the screen introduced too much movement. The overall process of manual focus on the E-P2 for me was very slow compared to the rangefinder.
