Fixer process's question
tuanvo1982
Hi all,
I am using ILFord rapid fixer 50mml for developing my FP4 roll. Last weekend, I had only 20ml left but actually I should have 60ml. I mixed 20ml with 280ml water. After that, I tried to find the time of fixer process by putting the leader of the film roll into mixed fixer liquid and check time until the film is clear. Finally I got result is 5 mins.
In paper work, they stated 60ml + 240ml and we need 5 mins however, with 20ml in 5mins I see the film is clear as well. So what is the purpose of wasting 40ml of fixer?
Btw, If we re-used developing chemical, do we have any way to check how long the developing process(I mean the 1st step) should take ?
Thanks
You will be surprised, but when you dilute your fixer even more and wait 24 hours your film will still get clear. However Ilford gave you you a certain mixing ratio in order to guarantee the process. Five minutes to clear your film in a fresh fixer solution is too long: as soon as your solution will be used when you fix a full film, the time to clear will increase and your process will become unreliable.
The same is true for the developer. A small volume of developer will be more prone to air-oxidation than a large tank. Therefore replenishment solutions are in place for large tanks while most people using small tanks rely on one-shot developers.
Peny-wise and pound foolish is that what the English like to say? Take care, Maarten
Old formulary suggest adding 10% for each roll over the previous roll. Total capacity is around 10 rolls per liter, but this can vary. If you add fresh developer to full the glass, of course you will have more power - and more active "live" for the bath.
Hi all,
Thanks
A one shot developer is the best way to stay away from all kind of crappy problems during the developing process.
The fix process is going into depletion.
If you make fixer for film: 1+4. You test the clear time and the right fixer time is 2x the clear time.
Slowly your fixer gets saturated with Ag+ (SIlver) ions. For film the limit is 2-3g ltr. Ag+.
You can test this with a 10% KI (Potassium Iodide) solution.
10ml fixer under test + 5 drops KI:
Milkey and clears up: under 2 g/ltr.
Stays milkey: over the limit.
In fact a chemical titration.
You can also count down the amount of film which has been done with the fixer solution. But also take notice that modern technology films (Tmax, Delta Acros) are blocking the fix process earlier: About 60% capacity left with these films.
Best regards,
Robert
