Metering vs Focus which takes priority
luccombelad
I'm a definite newbie to Photography, and I've read the manual....but...
I cannot understand the correlation between the focus area and the metering. Is there a strict correlation between the two.
For example, If I the focus set to spot, is the metering set to spot irrespective of what setting the metering is actually set to?
Thanks
It does not seem me there is a correlation: you can choice one of the 6 different autofocus option and from the menu you can choice one of the three metering option.
Than you can choice autofocus or manual or autofocus macro (small distance).
I hope this helps.
robert
Thanks Guys.
So the 'Green' rectangles in the viewfinder are purely there for focus, not metering?
Indeed they are.
Metering is always fixed in position for the 3 options (i.e. centre spot is always in the centre of the frame), whereas the green triangles can be moved around the screen should you wish.
Except when you choose spot metering and 1 point or spot focus. Holding the Delete/Focus button for 2 seconds and then shifting the "hot" area with the 4 direction arrows followed by the Menu/Set button will move both. HTH
Really? So when you move the focusing point around as described in both our posts, the metering also moves with it, if in 1 point or spot focus modes?
Hi Nick/Hilton,
Unless this has changed with the updated firmware then I think the spot metering area is always fixed in the centre and cannot be linked to the active auto focus area. I do not have my camera with me today but it is easy enough the test.
WOW - having just tested this, the following is the case:
1. When BOTH metering and Focus mode are spot, the metering is taken from the focus point NO MATTER where the focus point is moved to. The same is true if focusing mode selected is 1 point and the metering mode is spot.
2. When metering is NOT spot, it reverts to centre weighted or multi segment norms irrespective of where the focus point is moved to within the frame in spot or 1 point modes.
  • 2 weeks later...
