clip-in lens cap for A36?
jbl
The OP is looking for an A-36 clip-in cap for a 3.5/35mm Summaron. That would be the first generation of that lens and as such takes A-36 (push-on) or E-34 (clip-in) accessories, not E-39.
E-34 is rather scarce and finding it may be difficult. Google or a fleabay search is your best bet.
Cheers,
Jan
Well - I just did a fleabay search for '34mm lens cap' . Found quite a few clip-in ones - all you have to do is contact the sellers and find out if they actually mean a 34mm filter thread diameter (which is what you need) or 34mm outside diameter push-on (which you do not want).
The only problem may be that the 3.5/35mm LTM Summaron does not have 34mm filter threads and the clip-in cap may be holding by willpower only...;)
Good luck,
Jan
