lb1800 Posted December 3, 2011 Share #1 Posted December 3, 2011 Advertisement (gone after registration) Hi, I am new to film and have just acquired a lovely m6 ttl. (I thought this the best balance between modern acroutrements , ie it has a meter, versus not wanting to invest too much at this stage. It has the 0.85 viewfinder which I thought would help with longer lenses. My thinking was that if I go wider i would go wider than 28mm so the o.72 viewfinder wouldn't give me the right frame lines anyway. At least this way, I'm best places for 90mm). My question is around film processing. I bought some fuji superia and ilford hp5 to mess about with. Does the forum allow recommendations for processing services? I'm in London. Somebody mentioned something to me about getting B+W film processed through the normal colour process (is it called C41?) as it is cheaper than dedicated BW processing. Would be grateful for all advice on film buying + processing. I'm hoping to get the processor to scan the negs for me too. Thanks Link to post Share on other sites More sharing options...
Advertisement Posted December 3, 2011 Posted December 3, 2011 Hi lb1800, Take a look here Advice for a beginner. I'm sure you'll find what you were looking for!
fridland Posted December 3, 2011 Share #2 Posted December 3, 2011 my personal choice for a good b&w film go to a ilford Delta 400 and a ilford developpper ilfotech hc , is important to triyng for find a right devellopping time actually i overexpose the delta 400 at 320 iso and under develop the same , is very important to find a right time . Link to post Share on other sites More sharing options...
fridland Posted December 3, 2011 Share #3 Posted December 3, 2011 sorry , compliments for your excellent camera i have a M7 with a 35 mm and 90 mm Link to post Share on other sites More sharing options...
andybarton Posted December 3, 2011 Share #4 Posted December 3, 2011 You cannot process traditional black & white film, like Delta 400 or HP5, in C41 chemistry. If you are using traditional B&W film, you would be strongly recommended to develop it yourself at home. It's cheap, easy and much better than commercial processing. Link to post Share on other sites More sharing options...
earleygallery Posted December 3, 2011 Share #5 Posted December 3, 2011 My question is around film processing. I bought some fuji superia and ilford hp5 to mess about with. Does the forum allow recommendations for processing services? I'm in London. Somebody mentioned something to me about getting B+W film processed through the normal colour process (is it called C41?) as it is cheaper than dedicated BW processing. As Andy has pointed out, HP5 cannot be processed in C41 chems, you need C41 process B&W film - which is basically the same as colour neg but without the colour dyes. You can just shoot colour neg and convert the images to B&W in photoshop. Traditional B&W film like HP5 has a different look, and is very easy to process yourself. For a start, to get your films processed for you, try your nearest branch of Snappy Snaps. They do C41 on site and will also handle your HP5, and I've always found their quality reliable. Link to post Share on other sites More sharing options...
