Does a 21mm need a seperate viewfinder
macpants
  • Replies 65
  • Created
  • Last Reply
I've talked with 2 people who have been shooting with the 21/3.4 Super Elmar M since July and the images I've seen really impressed me. Now, I'm a big fan of the Zeiss 21/2.8 Biogon, and it served me well on the M8 and M9, but I've gotten used to the signature of Leica lenses. Yes, the Leica is more money than the Zeiss, but in the grand scheme of things, where the productive life of a Leica lens can be measured in decades, cost isn't really a factor.
I have no hesitation recommending the Zeiss lens to anyone on this forum, and I definitely don't recommend that everyone trade them out for the new Leica 21 SEM. But for me it's the right decision.
Stephen
Ideally, yes. You can get away without one with a little guesswork on the framing - unlike say, a 24/25mm lens which covers just about the entire internal VF.
is this true ?
I remember a previous similar thread on the 24mm when it was said that this was also outside the viewfinder.
It should be noted that the "image" of the M9 finder posted above is grossly unrealistic - (yes, I know it is Leica's own image originally). It shows a lot of area outside the 35mm frame that is not even close to visible in the real finder.
Below is the way the M9 finder really looks to the eye in practice - with image areas for 28, 24, and 21 lenses added.
For use with 21 or 24 lenses - the accesory finders are part of the "Leica M bargain." Accept them and use them - or buy a different camera.
Personally, I love the 21 focal length - and learned to deal with the accesory finder(s) years ago.
When I have used a 21 without a finder, I have found myself pressing my eye deep into the eyepiece. Then, I catch myself, rolling my eyeball around, looking inside the viewfinder for the edges of the frame. It is quite distracting and not conducive to effective composition.
Although I have the Zeiss viewfinder and not the Leica, it is much more effective to take photos with using an appropriate viewfinder. I do wish the Zeiss VF had other framelines to help with centering and composing the image, but it is much, much, better than going without.
Very good illustration adan. That is exactly how I perceive the viewfinder in my M9. It is possible to see the 28 frame lines without glasses but not much more. I find it more practical and enjoyable to use an external finder for 24 or wider. Since dof is reasonably large for these focal lengths it is not a problem to first focus and then move to the external finder for composition.
/Paer
Chimping won't kill you, but it takes time you should spend attending to the subject. I chimp occasionally in cases of dubious exposure, but NEVER to see what's in the picture!
When you are working, your attention must be on the subject, not on the camera. If the camera is more important to you than the subject, get an SLR.
The old man from the Age of Tri-X (definitely no chimping!)
+1
I have caught myself making this mistake when I first got my M9 and got back into photography, but now I only care about looking to see the histogram. That is why the proper VF, to me, is so important.
Actually using a 21mm lens and external VF is an incredibly fast solution for street photography. Set exposure manually and set zone focus and there is no need to look through the rangefinder window. I will shoot as I'm raising the external VF to my eye. I've also used this technique with a 35mm lens, composing in the center of the 21VF.
The street photography that I see is not happening at remotely the speeds I'm talking about.
The external VF slows you down, even if you are very fast with it you will be a lot faster without it.
Best,
Bill
Wow. Really?
It appears you are not open to the techniques or needs of others. Not all of us shoot only stationary or slowly moving subjects.
I'll keep my M9 and my 21 'lux and keep using it without a finder to great effect thank you.
Best,
Bill
Best,
Bill
If you do zone focusing, then an auxiliary finder is no slower than the camera finder – both are just a window to compose the picture in. If you have an accessory finder on the camera and zone focus, you simply don't use the camera finder for anything, so you are not switching from one to the other.
The old man from the Age of the VIOOH
Maybe I misinterpret, but it sounds like ohnri just shoots from the hip or just gets the shot without ever bringing the camera to his face/eye.
I have tried that with pretty good results with a GF1 & 20/1.7 and also the Panasonic P&S LX5, but never with an M9.
Agreed when zone focusing is adequate.
Shooting the 21 'lux wide open often makes zone focusing inadequate. In this case, the auxiliary finder is distinctly and unavoidably slower.
Best,
Bill
Best,
Bill
Bill, the only way faster is to "shoot from the hip", which I also do. However, when I have a second or two, I just raise the external VF to my eye and click away, having already set my zone focus and exposure. This makes the Leica the fastest camera for street photography.
As to your point about shooting wide open, I don't know many street photographers who do this. Most choose an aperture that will have sufficient DOF to capture the moment in context.
Stephen
Best,
Bill
?? If you zone focus it would be exactly the same... Except for that split second you utilize the actual frame lines to include or exclude something in the frame. However, if you don't care about what is included at the edges of your composition, then using the viewfinder might slow you down by maybe 1/2 second per shot.
Not at all. I generally use the 21 'lux at or near wide open in lousy light with fast moving subjects.
Not focusing carefully would leave me with rubbish for pictures.
Using an external VF would slow me down to the point of missing the majority of shots.
For street shooting, the subjects are a lot slower and more predictable and zone focusing or shooting from the hip is often effective. An external VF may even be useful.
Best,
Bill
Unfortunately, zone focus does not provide me with anything close to enough accuracy and 1/2 second may as well be an eternity.
Of course, for typical street shooting things tend to move slowly and predictably enough that zone focusing can be effective.
Not using a VF in no way implies not caring about the edges of composition.
No doubt that using an external VF will, at times, make it easier to "critically compose", but, using a DSLR or live view works even better. Maybe everyone that really cares about composition should shun CRF's and their wildly inaccurate framelines altogether. Just a thought.
Best,
Bill
