0.58 VF and 24mm
cbretteville
Anyone have experience using a 24mm on a 0.58 without an external finder?
Carl
Yes, I used a 24mm lens on a MP .58x, composing and framing with the entire VF perimeter. It works well, much like using the entire VF perimeter for the 28mm focal length works well on a M2. I hate the added bulk of an auxiliary VF and this one way of getting good framing without one.
YMMV
Thomas
No. Sucks as much as using a 28 with a 0.72.
Quite hard to have a general vision and understanding quickly.
Not using an external vf is entirely possible, even with a 0.72 abd approximating. But if you are serious and if your work is worthy, give it a chance: buy an external vf.
  • 3 weeks later...
  • 3 weeks later...
I also have an MP .58, chosen because I wear eyeglasses sometimes and specifically for the 24mm FOV. For three years now I have been mostly satisfied using only the finder's coverage, and have made lots of well-composed shots. However, I almost always have to remove my glasses to frame when greater precision is needed. I believe the external finder is more forgiving in this regard, with wider margins outside the framelines, but it does introduce the need to look through both finders to focus-then-frame if one cannot prefocus.
Of course, using the built-in viewfinder is a compromise: portability, simplicity, and reduced cost over perfect framing and less/no blockage.
This was quite adequate for a few years; now I'm reconsidering my kit and may get an external finder. I've also concluded that I need to add a 1.4x magnifier soon to improve the use of longer focal lengths--another consideration with the .58 viewfinder (becomes .81).
I have a lovely MP 0.58. It's great for the 35 and 28 framelines, and I even like using the 50 lines with it.
I have also found I can use the Zeiss 25 f2.8 without external finder and, although you have to move your eye around the edges of the finder its just fine. I prefer it to having an external finder, especially for street/reportage. I guess the 24 will be similar.
