Schnitzer Posted September 6, 2011 Share #1 Posted September 6, 2011 Advertisement (gone after registration) I have a Polaroid Sprintscan 4000 scanner that I would like to start using again. I originally had it operating on a Windows 98 system, I am trying to implement it now on a computer with a Windows XP operating system, but can't to get it to initialize. The original software will not work on XP. I have tried using pci_55_1.exe software which is supposed to work with XP. In my investigation for failure to initialize, I have also read to use pci_50_1.exe which was said to work with XP. Neither one has enabled the scanner. Has anyone had any experience using this scanner with Windows XP? If so, I would appreciate any help you can provide. Schnitzer Link to post Share on other sites More sharing options...
Advertisement Posted September 6, 2011 Posted September 6, 2011 Hi Schnitzer, Take a look here Initializing Scanner . I'm sure you'll find what you were looking for!
andybarton Posted September 6, 2011 Share #2 Posted September 6, 2011 Try Vuescan from VueScan Scanner Software for Windows 7, Mac OS X Lion, Linux, iPhone, iPad, iPod Link to post Share on other sites More sharing options...
eyedeebee Posted September 6, 2011 Share #3 Posted September 6, 2011 Second the Vuescan suggestion. Link to post Share on other sites More sharing options...
philipus Posted September 9, 2011 Share #4 Posted September 9, 2011 I have a Polaroid Sprintscan 4000 scanner that I would like to start using again. I originally had it operating on a Windows 98 system, I am trying to implement it now on a computer with a Windows XP operating system, but can't to get it to initialize. The original software will not work on XP. I have tried using pci_55_1.exe software which is supposed to work with XP. In my investigation for failure to initialize, I have also read to use pci_50_1.exe which was said to work with XP. Neither one has enabled the scanner. Has anyone had any experience using this scanner with Windows XP? If so, I would appreciate any help you can provide. Schnitzer Vuescan is great and the Polaroid Sprintscan 4000 is supported. Check here for instrux. Polaroid SprintScan 4000 Scanner Driver and Software Good luck! Philip Link to post Share on other sites More sharing options...
Schnitzer Posted September 14, 2011 Author Share #5 Posted September 14, 2011 I was unable to install the scanner with VueScan. During the installation process, VueScan specified that a Scan disc (Scan.msi) had to to be used. Tried using the XP recovery discs but Scan.msi was not found. Apparently the scanner will not install because of a software error on the computer. Since VueScan is compatible with Windows 7, I would like instead to connect my Sprintscan 4000 to my Windows 7 computer. This would require a Ratoc U2SCX USB-to-SCSI adapter. indicated by VueScan. Have not found any available. Ratoc website says they have been discontinued. Any suggestions for where to go from here as I seem to be hitting dead ends? Link to post Share on other sites More sharing options...
cbretteville Posted September 15, 2011 Share #6 Posted September 15, 2011 SCSI is no longer the prevalent interface it was 15 years ago. But as allways, Google is your friend: Amazon.com: Ratoc USB2.0 to Ultra Wide SCSI Converter: Electronics Alternatively you could: - find old hardware on eBay and use Win98 - find a scanner that has a USB interface Carl Link to post Share on other sites More sharing options...
Schnitzer Posted September 27, 2011 Author Share #7 Posted September 27, 2011 Advertisement (gone after registration) My Sprintscan is working fine now. I was able to buy locally a used computer with Windows 2000. I plan to stay with the Polaroid Insight software inasmuch as I didn't see any advantage going with VueScan. Thanks for the helpful responses that were offered. Link to post Share on other sites More sharing options...
