24 lux filter artifacts
dcuthbert
afternoon all,
started to notice a rather annoying issue when using the 24 lux on the m8. It seems (well in my opinion at least) that the IR filter is possibly causing artifacts in some light situations.
Example one (dark, outdoor light, 640 ISO and manual
Example two (interior shot, good available light)
As you can see on both of their faces, this weird blue hue exists. Any idea what on earth could be causing this?
It's hard to tell without seeing the whole image.
These certainly do look like internal reflections (quite possibly from the filter) of light sources in the image.
I know it's not always convenient in cases like this, but you could try making the same shot with and without filter. Maybe set up a couple lamps in the frame and maneuver the camera till (if) you get the smudge, then repeat without the filter.
I suspect it's "ghosting" (is that the right term?)
Often happens when you shoot with a filter at night into a direct/strong light source. Not exactly a problem exclusive to the 24 Lux filters, but I do see this problem a lot when I'm using my 24 Lux at night.
Yeah it's ghosting. Nothing to do about except avoid having bright lights in the edges or just outside the frame.
Yes, sorry wrong labels. It does indeed happen the most at night, although this is the first time i've seen it during the day.
Look I guess I could take off the filter, but what a hack to have to remember to do that. Very frustrating. Thanks for all the responses though
