martha Posted August 22, 2011 Share #1 Posted August 22, 2011 Advertisement (gone after registration) I just had some fun making some infrared images with my M8.2 and a B&W 093 dark red filter. In Lightroom they have a magenta cast. What are your recommendations for removing that cast? ( I slid the "tint" slider in Develop all the way to the left.) Is there anything more I should do or is there an alternative fix for this in Lightroom? Thanks in advance for any advice.--martha Link to post Share on other sites More sharing options...
Advertisement Posted August 22, 2011 Posted August 22, 2011 Hi martha, Take a look here How to remove magenta cast when making IR images. I'm sure you'll find what you were looking for!
stunsworth Posted August 22, 2011 Share #2 Posted August 22, 2011 Desaturate then adjust shadows/highlights etc. as required. The 093 filter doesn't allow any colour information to pass through it. Link to post Share on other sites More sharing options...
jaapv Posted August 23, 2011 Share #3 Posted August 23, 2011 Click a medium exposed area with the color balance eyedropper and proceed as you would with a B&W image. Link to post Share on other sites More sharing options...
martha Posted August 24, 2011 Author Share #4 Posted August 24, 2011 Thank you!!! Both methods work much more efficiently than mine.--martha Link to post Share on other sites More sharing options...
jevidon Posted February 3, 2013 Share #5 Posted February 3, 2013 Re.: workflow, I simply click on black & white image in the image>adjustment drop down menu in CS5 and then touch it up with contrast a little. If the image is slightly soft because you didn't adjust for IR focus exactly, try high pass filter sharpening and then adjust the slider down to about 20-25 and then flatten the image and save. If you don't like the slight amount of noise, you can reduce it, but only do it a little bit before you do the sharpening. Perfection! I also tried using NIK Silver Efex Pro, which did the job, but the above method gives a cleaner image, at least in infrared. My M8 setting are RAW, ISO 320, EV - 1/3, WB=2000K. I've been using the Hoya R72 filter with my 35mm Nokton f1.2, but I have a 39mm B+W 092 on order for my Leica glass. I shoot at 1/30 sec for hand holding in bright sunlight and bracket the aperture from f8 to f16 and then pick the best for printing, depending how I want my shadows and highlights to look. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/159987-how-to-remove-magenta-cast-when-making-ir-images/?do=findComment&comment=2231945'>More sharing options...
Guest WPalank Posted February 3, 2013 Share #6 Posted February 3, 2013 Color channels should still be available, go to Curves> Green Curve, place a point in the highlights, shadows, or mid tone. Drag the curve up in the area.most affected. If slight, click on a point on the curve and gently tap with the up or down arrow until,balanced. Link to post Share on other sites More sharing options...
kdriceman Posted February 3, 2013 Share #7 Posted February 3, 2013 Advertisement (gone after registration) I found this helpful when I set up my IR workflow. http://www.aeos-photo.com.au/blog/2011/03/31/how-to-properly-shoot-and-edit-ir/ Link to post Share on other sites More sharing options...
jevidon Posted February 5, 2013 Share #8 Posted February 5, 2013 kdriceman, Interesting technique, but I'm not sure it is any better than the one I've been using. nevertheless, I installed some profiles in LR4 and I'll play with it. Link to post Share on other sites More sharing options...
