Testing a photo post ...
SiMPLiFY
I just tried shooting a negative with my Nikon D70 and a Macro Lens. I used a negative carrier from my old Epson 2450 and stood it up on a box. I used my iMac with text edit open for my light source. I used manual focus f/8 and 1/5 of a second. I inverted in Photoshop + did levels and curves. I converted to B&W, 8 bits, reduced image size and saved for web. So ... is this a good enough process to be able to share photos on this forum?
This is some random photo from Chartres in 2008 and I used T-Max 3200 pushed to 6400 and a soft filter to keep the grain in check.
I would say so. What you are doing I have also done. I have a Pentax bellows with slide/film copier attachment that I used to copy slides with my Pentax DSLR. My set up allows me to reverse the standard lens for a flatter field, something you do not have to do with your lens. I got ok results with it. I then tried projecting the slides on a 4 x 4 screen using a standard projector and again shooting the image with a DSLR. I actually got better results. Keep at it.
Wayne
This was a grab a negative out of a case - shoot - process quickly - post - without much thought.
As much as I LOVE this Cathedral - iT iS DARK! Probably the worst possible negative I could have ever randomly selected! GRAiN anyone???? LOL!
I do plan a 36 exposure - one lens - one leica day this weekend. Of course I am using film so ... I'll see if I can't give it another go after I've dunked a new roll with computer sharing in the back of my mind.
I've already forgotten photoshop which I was quite proficient in a few years back? I am still in CS2 Land! LOL!
Kathleen
sorry but I did not understand by reading ....
In principle this is how I do :
From the negative, I scan on my Epson V700 or V750
I use one of two scanner software EpsonScan or SilverFast software
without modification
Then with LR I modify if necessary (a little more contrast or clarity...) but usually I do not need and I post
Best Henry
Yours looks really fine to post here. I find around 100 pip gives best results for web as most modern monitors are around 100 pip. Sharpen with low radius, around .5 pixel, point 5 pixel.
If you want the best possible file for prints, then some better scanning would in order.
