NikonJeff Posted August 8, 2011 Share #1 Posted August 8, 2011 Advertisement (gone after registration) Good afternoon! Long time lurker and previous M6 owner... I recently purchased a used silver M8 (s/n 3108xxx) and I noticed immediately that there seems to be quite a bit of play (side to side and forward/back movement) of the shutter release/mode selector assembly. Is this a "normal" thing or should I be concerned? The body is pristine and registers just over 2500 actuations. Looking forward to getting back into Leica shooting! Thank you in advance for any insight... Jeff Guntert Schenectady, NY Link to post Share on other sites More sharing options...
Advertisement Posted August 8, 2011 Posted August 8, 2011 Hi NikonJeff, Take a look here Loose shutter release/mode switch?. I'm sure you'll find what you were looking for!
JKphotography Posted August 8, 2011 Share #2 Posted August 8, 2011 Hi there Jeff! Welcome to the forum! My shutter release / mode selector is pretty stiff on my black M8. I do sometimes notice i select C mode when i turn on the M8, but that;s a pretty common thing. Regards, Joël Link to post Share on other sites More sharing options...
NikonJeff Posted August 8, 2011 Author Share #3 Posted August 8, 2011 Hi there Jeff!Welcome to the forum! My shutter release / mode selector is pretty stiff on my black M8. I do sometimes notice i select C mode when i turn on the M8, but that;s a pretty common thing. Regards, Joël Hi Joel, Thank you for the reply. It's not that mode selector moves from off, S,C and self timer - the entire ring ad shutter release move around like it needs to be screwed down... Jeff Link to post Share on other sites More sharing options...
hx911 Posted August 9, 2011 Share #4 Posted August 9, 2011 That does not sound right. No play in the switch of my M9, and the M8 was the same. Better have it looked at / repaired. Link to post Share on other sites More sharing options...
NikonJeff Posted August 9, 2011 Author Share #5 Posted August 9, 2011 That does not sound right. No play in the switch of my M9, and the M8 was the same.Better have it looked at / repaired. I figured it out - there are three screws holding the actual release button/mode switch to the top plate assembly. All three screws were extremely loose... Not a tear apart for the faint of heart! Link to post Share on other sites More sharing options...
twelve Posted August 12, 2011 Share #6 Posted August 12, 2011 I figured it out - there are three screws holding the actual release button/mode switch to the top plate assembly. All three screws were extremely loose... Not a tear apart for the faint of heart! How did you get it sorted? Mine seems a little loose too!.. Thanks Link to post Share on other sites More sharing options...
jaapv Posted August 12, 2011 Share #7 Posted August 12, 2011 Advertisement (gone after registration) You'll find the answer here: http://www.l-camera-forum.com/leica-forum/leica-m8-forum/21331-anatomy-leica-m8.html Link to post Share on other sites More sharing options...
NikonJeff Posted August 12, 2011 Author Share #8 Posted August 12, 2011 You'll find the answer here:http://www.l-camera-forum.com/leica-forum/leica-m8-forum/21331-anatomy-leica-m8.html You'll see plenty of photos but no explanation as to how the top cover comes off. In the 9t photo down you will see the underside of the shutter release/mode selector. If you remove the (4) silver screws from the square block there will be (3) screws underneath that that actually hold the shutter release/mode selector to the top cover of the camera. Those (3) screws were all WAY loose on mine. To remove the top cover of the camera you need to remove the bottom plate, battery and SD card. then remove the (5) very small and easily stripped philips screws from the black plastic cover that makes up the "inner" base plate. Once that is done there will be (3) small philips head screws in the cavity under the shutter release area that need to come out. On the viewfinder side of the camera there is a hole to stick a screwdriver in to remove the remaining philips head screw. The top plate is now loose - watch out for the ribbon circuit when pulling the top cover off. Jeff Link to post Share on other sites More sharing options...
