SD Card Tests with and without M9
Robert_M
Hi Scrubs,
Many thanks for this considerable amount of work that I greatly appreciate.
Before folks start reporting, the forum needs to develop a consensus with Leica of what is a complete relevant M9 Problem Reporting Template.
In addition to the information you just provided, I would like to suggest the following as well:
M9 firmware version
Lens used
Memory card used
Also, after your list the question I posted before.
I plan to go over this shortly and put together an even more complete list.
But you already did the bulk of the work.
Many many thanks for that.
With best regards, K-H.
I'd suggest also adding.
M9 serial number & type (or M8 serial number etc.)
Who knows what differences there may be.
If it might help Leica I'd post the memory card to Solms as well with paper copy of problem report proforma. Some of the problems may be timing issues between the M9 and card, or mislabeled (e.g. counterfeit) cards.
Noel
  • Replies 132
  • Created
  • Last Reply
Noel
good Idea Noel
Edit: ah bugger... I missed the editing deadline - forgot about that feature so It won't let me edit it anymore.
Anyway I will hand that thread over to the mods to make any small additions, If the thread turns out to be
of help.
As the other thread http://www.l-camera-forum.com/leica-forum/leica-m9-forum/193908-m9-problem-reporting-template.html is fortunately closed, we will continue discussion about an M9 Problem Reporting Template here.
This is another iteration in producing a template for reporting M9 problems. Thanks to everybody who provided feedback, especially scrubs.
It is intended for discussion and feedback of forum members to admin Andreas Jürgensen to talk with Leica.
I was thinking - wherever possible - of a multiple choice format so that reporting folks have a minimum amount of work to do.
For example:
M9 firmware version, choose one:
1.162
1.138
1.116
1.002
So, in reporting this would look for firmware version 1.162 like this:
1.162
1.138
1.116
1.002
So, here goes the modified proposed list in systematic order:
Proposal: M9 Problem Reporting Template
M9 Serial Number please, don't show last 2 digits:
1.162
1.138
1.116
1.002
Lens mounted, please describe uniquely:
Memory card used, please describe uniquely:
Power switch set from OFF to:
S
C
Timer
Exposure wheel set to:
A
B
8s
in between
4s
in between
2s
in between
1s
in between
2
in between
4
in between
8
in between
15
in between
30
in between
60
in between
125
lightning symbol
250
in between
500
in between
1000
in between
2000
in between
4000
Menu Button items:
Lens detection
Off
Auto
Manual
16-18-21 ASPH F/4 @16mm 11626
16-18-21 ASPH F/4 @18mm 11626
16-18-21 ASPH F/4 @21mm 11626
21 f/2.8 11134
21 f2.8 ASPH 11135/11897
24 f2.8 ASPH 11878/11898
28 F/2 ASPH 11604
28 F/2.8 11804
28 F/2.8 11809
28 F2.8 ASPH 11606
28-35-50 ASPH F/4 @28mm 11625
28-35-50 ASPH F/4 @35mm 11625
28-35-50 ASPH F/4 @50mm 11625
35 F/1.4 11869/11870/11860
35 F/1.4 11874/11883
35 F/2 11310/11311
35 F/2 ASPH 11879/11882
50 F/1 11821/11822
50 F/1.2 11820
50 F/1.4 11868/11856/11114
50 F/1.4 ASPH 11891/11892
50 F/2 11817
50 F/2 11817
50 F/2 11819/11825/11816
50 F/2.8 11831/11823/11824
75 F/1.4 11814/11815/11810
75 F/2 ASPH 11884/11885
90 F/2.8 11800
90 F/2.8 11807/11808
90 F/4 11633/11634
MACRO-ADAPTER-M F. 90 F/4 14409
135 F/2.8 11829
135 F/3.4 APO 11889
135 F/4 11851/11861
Save user profile ?
Advance
Standard
Soft
Discreet
Discr. & Soft
Self Timer
Off
2s
12s
Auto ISO Setup
Slowest Speed
Lens dependant
1/125s
1/60s
1/30s
1/15s
1/8s
Max ISO
PULL 80
ISO 160
ISO 200
ISO 250
ISO 320
ISO 400
ISO 500
ISO 640
ISO 800
ISO 1000
ISO 1250
ISO 1600
ISO 2000
ISO 2500
Sharpening
Off
Low
Standard
Medium High
High
Colour Saturation
Low
Medium Low
Standard
Medium High
High
Black & White
Vintage B&W
Contrast
Low
Medium Low
Standard
Medium High
High
Bracketing setup
No. Of Exposures
3
5
7
Sequence
0/+/-
-/0+
Ev Increments
0.5EV
1 EV
1.5 EV
2 EV
Exposure Comp Setup
SET menu only
Setting ring
Set. Ring & Rel. But.
Monitor Brightness
Low
Medium Low
Standard
Medium High
High
Histogram
Standard
RGB
Clipping Setup
Off
Over exposure only
Over / Underexposure
Folder managem. ?
Auto review
Duration
Off
1s
3s
5s
Permanent
Rel. Button Pressed
Histogram
On
Off
Auto Power Off
1 min
2 min
5 min
10 min
Off
Flash Sync
1st Curtain
2nd Curtain
Auto Slow Sync
Lens Dependant
Off (1/180s)
down to 1/30s
down to 1/8s
down to 32s
Color Management
sRGB
Adobe RGB
DNG Setup
Uncompressed
Compressed
Reset ?
Sensor Cleaning ?
Date ?
Time ?
Acoustic Signal
Volume
Off
Low
High
Keyclick
Off
On
SD card full
Off
On
Language (doesn't seem to work properly)
English
German
French
Italian
Spanish
Japanese
Trad. Chinese
USB Connection
Mass Storage
PTP
Format SD card ?
Firmware 1.162 or older, please fill in:
ISO Button Items:
Auto ISO
PULL 80
ISO 160
ISO 200
ISO 250
ISO 320
ISO 400
ISO 500
ISO 640
ISO 800
ISO 1000
ISO 1250
ISO 1600
ISO 2000
ISO 2500
INFO Button Items:
Battery, please estimate status in %:
SD card, please estimate status in %:
Remaining pictures, please fill in status:
Shutter speed: Non applicable
Lens, please fill in status:
SET Button Items:
White Balance
Daylight
Flash
Cloudy
Shade
Manual
Kelvin Setting?>
Compression
DNG
JPG Fine
JPG Basic
DNG & JPG Fine
DNG & JPG Basic
Resolution
1MP
2MP
4.5MP
10MP
18MP
Exposure Comp.
-3
-2 2/3
-2 1/3
-2
-1 2/3
-1 1/3
-1
-2/3
-1/3
0
+1/3
+2/3
+1
+1 1/3
+1 2/3
+2
+2 1/3
+2 2/3
+3
EXP Bracketing
Off
On
Set User profile ?
Ambient Temperature, please estimate:
freezing
cool
room Temperature
warm
hot
Symptom Description & Additional Comments:
Please describe as detailed as possible, what happened (did you do) before the problem, during the problem episode, and afterwards to get your M9 back into functioning semi-correctly.
Did you subsequently investigate your memory card thoroughly?
Format it? Check it out on a computer, another camera?
After formatting with Overwrite in M9 is the situation back to normal - whatever that means?
How long did the format take?
Please, post in this thread corrections and additions. I will incorporate them for a final version of this proposal. Thanks.
Obviously, we also need to flesh out and agree upon how to properly and correctly examine a memory card to establish its status. But that's another exercise.
Cheers, K-H
I cannot imagine anybody filling out such a list.
Jaap,
Yup, we'll see. Not many for sure. I certainly will.
I also want to give an example of what a systematic effort may require.
I hope Andreas and Leica will trim this list way down according to Leica's requirements.
But we hopefully give them enough info not to overlook something obvious.
Such a template, including a reduced version, should also be handy once Leica has issued a new firmware version hopefully soon.
It would be nice to know which parameter sets are most suspect and need specific attention.
Thanks, K-H.
Hi Karl-Heinz--yes, it's the original 85 1.4 Nikkor that has the problem. With that lens in place, my D3 has been the least reliable camera I've ever used, and Nikon can't seem to fix it... :(
The answer appears to be "buy the newer version lens" but I have other things slated for that $$
Anyway, back on topic, I tried to make my M9 fail this morning in C mode. Nothing doing...it worked well full buffer or no.
BTW--why do people even put cheap cards in their M9? A system is only as good as the weakest link in the chain, and storage isn't a particularly easy task to accomplish.
I wonder if the S2 and the Fujitsu processing stream experiences the same issues?
Hi Jamie,
Thanks. I agree completely with that.
Best, K-H.
Jaap,
Thanks, K-H.
Let's hold our horses until Andreas/Leica have set out a framework. It is all a bit of a waste of effort right now.
I must agree that the length of the list seems overwhelming. You should know by now that I'm willing to put in considerable time and effort in tests and writing explanations. At the same time, I'd be reluctant to spend the time filling out such a long list. Just a personal response, so take it for what it's worth.
(Actually, a technology financial fund manager once told me that the value of advice is worth what you paid for it. Since these comments are free, you know how valuable they are....:rolleyes:)
I'd suggest a much shorter list which is easy to apply check marks or fill in the blanks. It is an excellent idea to get some input from Leica as to what they want as feedback (I do hope they want feedback).
RM
Well, I had tried the continuous shooting test this morning. Oddly enough, I had actually done this before reading the last few pages of this thread. I had been interested in if my M9 really did 2 fps continuous shooting. I never use this mode and wanted to know.
Relevant parameters:
C mode
ISO 160
no bracketing
shutter speed 4000
Sandisk Ultra 16 GB card (latest generation) about 1/2 full
DNG full only (no compress, no jpg)
1) I fired off 7 shots before it stopped. Time was about 3.5 to 4 sec (just using my watch to measure). Fine. Did not continue to hold shutter button. IMPORTANT (I think): Battery began as 1/4 full. And then the camera went on and on and on and on with the blinking light. I got tired of this after several minutes and pulled the battery to stop and reboot. Tried another battery. Took many tries and many attempts to revive the camera at all! By this I mean that there was absolutely no response in coming back to life. Finally, with a full battery, it came back alive and resumed where it had left off before I tried the test. There was absolutely no image recorded. You can imagine my heart skipped a few beats and I thought that enough is enough of testing. For awhile, it seemed that the camera had been killed completely!
2) Well, I then read the above 2 pages of posts and thought that this is not an unreasonable test after all. So with a fresh battery (95% full), I did the same test again. Brave of me (or am I just foolish:rolleyes:)? This time I also held down the shutter button to measure the following frames. If I measured right,
7 frames and then pause for about 20 sec (again, a watch and my reading error).
following frames at intervals of about 8 sec
10 frames total and all got recorded.
I think this conforms to what is expected. However, there was one anomaly. After I released the shutter button, the blinking light went on adn on and on. I got impatient after a couple of minutes and then changed the switch from C to S and the blinking stopped. Coincidence or causal effect, I don't know.
I have the sneaky hunch that the battery level has something to do with the problems. That is not unreasonable. I will note that at 25% level, the M9 will not let one reformat a memory card in overwrite mode (it rightfully tells you that the level is too low). So maybe....
For what it's worth.
RM
Way back on the original postings of this thread and comments to K-H about a similar test in Mac OS......
Well, you will recall the original posting of H2testw testing in MS windows and the failure. I found a similar, simple test in Mac OS and it fails the same way. I did this testing on a recent Mac Mini with Leopard OS.
- Use the utility in the Mac OS called Disk Utility.
- Use the settings which will do a secure erase which write "0" to all locations (once, don't bother with the extra repeated writing of "0"). This test is simply writing a 0 to all locations on the SD card memory to securely erase the entire contents so it can never be recovered. This is a very simple write task, but all done continuously.
- First do this secure erase to an SD card through a card reader. In my case, I used the same card as #7 in my previous testing (a vintage Sandisk Ultra II 2 GB). This works fine and has no problems.
- Next, put the M9 in mass storage mode. Put the same card in the M9. Format the card in the M9 (if you wish, but really this is not relevant - yes I did do this).
- Now try the same secure erase.
Again, through the M9, the task failed badly. It all crashed in the last 10% of the card size. It did work fine up to that point. This is the same as before using H2testw and windows xp.
Actually, it failed worse than before since it seems to have completely crashed the critical knowledge of the format structure of the SD card.
I also found that Mac OS can not recover or recognize the card with the formatting gone. The M9 also thinks there is no card when inserted. A windows OS computer and a Linux system will happily reformat the card. Also, an old Canon G9 (vintage 2007) will see the card as a "card error" but will reformat it. Now isn't that interesting: A 4 year old Canon "point and shoot" does a better job of recognizing and formating a really bland SD card than Mac OS. Go figure.
After reformatting the card, all is well.
As I contended before, these are different tests than K-H did by filling his card in steps. What is the difference? These tests are continuous, sequential writing tests to the card. His test filled the card in various ways with stoppages and camera power off in between.
Again, this configuration will only test the USB and SD card interfaces in the M9. All the image processing functions are not used (unless I mess something). But that is the point: isolate the test to a particular function. And, this is now tested with 2 different computers and 2 different OS's.
What I see is that the M9 can not complete a continuous sequential write to the SD card via the USB interface. This is a fundamental requirement of a "mass storage" device. Remember, Leica does say that the M9 can be used in mass storage device mode (see the manual).
Maybe my M9 is different? Maybe it depends on various cards (but I'm not about to continue testing 20 different cards). I did use a simple, Sandisk, 2 GB card for this test - one of the least troublesome of any reports. I welcome others to try one of these tests. I'm disappointed that no one else has reported repeating one of these simple tests of the interface.
RM
RM
I can confirm Robert's finding that the USB connected memory card in M9 fails to be reliably erased with zero overwrite with Disk Utility.
However, I cannot confirm Robert's assertion "that the M9 can not complete a continuous sequential write to the SD card via the USB interface."
Equipment used:
• MacBook Pro with Mac OS Lion
• Panasonic PASD8GBU1 8GB SDHC-UHS-I Memory Card
• Delkin Devices DEMCRU30 USB 3.0 Universal Memory Card Reader
Tests performed
• Mount USB connected Mass storage memory card in M9 on Mac OS Lion, takes about one minute, much much longer than on Snow Leopard.
• Erase card in Delkin with zero overwrite with Disk Utility on Mac, works.
• Erase card in M9 via USB with zero overwrite with Disk Utility on Mac, fails towards the end.
• Erase card in M9 via USB with zero overwrite with Disk Utility on Mac, fails badly earlier, card not recognized by M9 when USB cable removed.
• Erase card in Delkin with zero overwrite with Disk Utility on Mac, fails.
• Erase card in Delkin no overwrite with Disk Utility on Mac, works.
• Erase card in M9 with Yes, card finally recognized by M9, works
• Erase card in M9 with Overwrite, works.
• Erase card in M9 with Yes, works.
• Shoot 10 images, works.
• Mount USB connected Mass storage memory card in M9 on Mac OS Lion, takes about one minute.
• All 10 images are okay.
However
Drive Genius 3 on Mac successfully scans and shreds the entire via USB connected memory card in the M9 in one seemingly continuous operation.
Subsequently Performed Tests
K-H.
There really is no need to Quote the entire post immediately above yours... it just makes a thread twice as long and more difficult to read. Thanks.
What Robert has done is, I suppose, interesting, but completely mad, IMHO. Who would even think about zeroing out a card, using Disk Utility, when the card is in a camera? Only in exceptional, extreme circumstances might one even think that this would be a great idea.
The M9 mass storage mode is to allow downloading of images to your computer. It isn't designed to ape a card reader and I amazed that anyone might think that it would.
I really do think that you are trying to find problems where there are none.
I know that you are trying to push the M9/SD card interface as far as it will go, but to what purpose? Leica have said that they are working on the card write problem. They will, no doubt, have all sorts if diagnostic equipment available, as will their partners Jenoptik.
I seriously believe that you are wasting your time here (which is your right, of course!) and it would be better to wait until Leica ask for specific information to help with the problem, rather than scatter gunning diagnostic tests which may be completely irrelevant.
RM
Hardly surprising, seeing that the relevance of the test is unclear to anybody but maybe a sofware engineer with access to the codes of Leica's firmware, i.e.somebody from or working with Leica.
I see there is a bit of cross-posting between moderators going on here ;)
My advice would be to wait until a call to arms comes from Leica. You could easily be barking up the wrong tree here. Indeed, a fix for the write problem might be very simple, who knows?
I have been thinking that the test is akin to someone saving a DVD to an SD card, then wondering why it couldn't be played on a computer, via an M9. No doubt, someone will be along shortly to say that this is how they always watch DVDs on the road - when using their Fuji X100 :)
Just trying to save people from a lot of potentially abortive work.
I was going to suggest that people go and take some photos instead, but that's not possible.
I am just trying out how many lines are required to fill in the entire template.
Turns out, not bad at all in my assessment. Here goes
M9 Serial Number please, don't show last 2 digits: 38038xx
M9 firmware version, choose one: 1.162
Lens mounted, please describe uniquely: Tele-Elmarit-M 90/2.8
Memory card used, please describe uniquely: Panasonic PASD8GBU1 8GB SDHC-UHS-I
Power switch set from OFF to: S
Exposure wheel set to: A
Menu Button items:
Lens detection Manual 90 F/2.8 11800
Advance Standard
Self Timer Off
Auto ISO Setup Lens dependant
Sharpening Standard
Colour Saturation Standard
Contrast Standard
Bracketing setup 5 / -/0+ / 0.5EV
Exposure Comp Setup Set. Ring & Rel. But.
Monitor Brightness Standard
Histogram RGB Over / Underexposure
Folder managem. Leica
Auto review Duration Permanent, Histogram On
Auto Power Off Off
Flash Sync 1st Curtain
Auto Slow Sync Lens Dependant
Color Management sRGB
DNG Setup Compressed
Acoustic Signal Volume Off Keyclick Off SD card full Off
Language English
USB Connection Mass Storage
Firmware 1.162
ISO Button Items: ISO 160
INFO Button Items:
Battery, please estimate status in %: 87%
SD card, please estimate status in %: 98%
Remaining pictures, please fill in status: 415
Lens, please fill in status: 90 f/2.8
SET Button Items:
White Balance Auto
Compression DNG
Resolution 18MP
Exposure Comp. 0
EXP Bracketing Off
Ambient temperature, please estimate: room temperature
I take one shot, switch power off and on while red LED is blinking, result: all buttons in the back are dead. Works every time that way like a charm! :D
To get the buttons functioning again, I either press the shutter or switch off and on again. :)
BTW, images are all there and not corrupted.
No.
Not Applicable
I wonder whether my M9 is the only one that behaves that way?
Cheers, K-H.
