Any Pan F users out there?
aesop
  • Replies 53
  • Created
  • Last Reply
This one was taken with the Rollei film. I know that Carl Bretteville has used this too - more than I have.
Three Musketeers
I must get some more.
...great detail here, Andy - any examples of indoor or pseudo-low-light shots? I know 32 ISO is way out there, but that's where the M's strengths kick in. IMO.
Three Musketeers
...thanks, Mauro - could you please expand on "lovely"?
It allowed me to shoot wide open with graet ease... However, I found it not to be quite grainless as said, although I was still pleased with the results.
Here are a couple of examples:
Pan-F will work, but you may want to look at Efke 25. This is a fine grain B&W film with "unique" tones. I develop mine in Rodinal and am always impressed with the results. It is a bit contrastry in direct sunlight, but I handle that by overexposing a stop and pulling back development by 20%. In shade, I just process normally. Efke 25 is now my standard low ASA film.
Jim B.
Jim B.
PAN F 50
No. Using 32 ISO indoors is pushing it a bit
I have shot a few rolls wih ATP 1.1, I have about 10 rolls left and doubt I will ever use it for anything. The tonality is fantastic and the grain is not there, but I find it increadibly hard to develop. I get dark spots in blue skies and there is a sheen on the developed film that I have tried to remove using my fingers. In addition this is the only film that gives me drying stains despite using deionized water and Tetenal Mirasol in the final rinse. I even bought a Paterson plastic tank specially for use with ATP as I thought my steel tank and reels were the source of the dark spots (read Rollei's doc).
Sad but true. I still have TechPan left so that is what I'll be using when needing a slow, fine grain emulsion. That said I'm going to try Adox's CMS20 having bought a test-kit from Fotoimpex.
Carl
Carl
...thanks, christer - I am looking for "image quality, fine detail and lack of grain". At least that is what it said on the Ilford literature that initially piqued my interest in Pan F+.
What speed do you normally rate your TMY at?
800
I just last week used my Canon EOS3 to do some film speed testing because with that camera bracketing is so easy. I bracketed around 800 and my conclusion was that the quality of 800 prints does not differ that much from the 400 prints, except that some shadow detail may be lost.
I also shot zones 1-9 using a grey card and measured the densities with a RH Design "Analyser". When exposing at 800, then zone 1 is almost blank, but on a print this is often irrelevant.
I tested TMX at the same time. The result is similar if you insert 200/100 instead of 800/400.
With regards to the TMY/TMX difference in grain, the difference in grain size and structure is there when a loupe is used to look at approx. 14x enlargements. Without a loupe, the difference becomes more or less a matter of taste.
BTW, I used Xtol 1+1 for the test
Pan F in Ilfotec DD-X was my primary B&W film from about 2000 until I quit using film regularly. I still wind a roll of PanF 120 now and then.
Main reason - I found the tonality to be better for scanning than TMax 100. TMax was probably less grainy and sharper, but always had a metallic "stiffness" to the highlights, which Pan F handled better, especially exposed at EI 80.
Pan F does have the finest grain of the current "old tech" films - absent the microfilms (which to my eye have the same problems as TMax).
Here's one shot that perfectly shows the "endless" white-on-whites Pan F could capture:
Guest Randle P. McMurphy
Would particularly like to hear from hand-held clickers and experienced home processors.
Didnt work with Ilford since Fuji started their Neopan films.
Neopan 400 was much better than HP5 oder HP5+.
For best resolution I used APX 25 as long as avaiable and
then tried T-MAX 100 as long as Fuji released the best film
ever = Across 100. It´s a deam - and easy to handle even
if you want to process it on your own or give it away. :)
I used it with Ilfosol. 6 minutes. Clean tones. Grain-free. Don't have any scans unfortunately.
I shot in daylight, so I had no problems. Generally aperture was about 5.6-11 with shutter between 500-125.
