Light Meter ? X1
lykaman
Well, I'm not really trying to give you a bad time by writing this, but if you have to ask this question, the likely answer is "no." It takes quite a bit of experience and judgement to use a manual light meter as accurately as the built-in light meter of the X1 does it automatically.
I do, however, recomment that you buy a used light meter, a good but inexpensive one, and learn to use it. That way, the above might not be true, always.
Only in the most extreme circumstances, or in the studio. But the X1 is designed to be a compact companion without the need for a multitude of extras. What difficulties are you encountering using the excellent in-built exposure meter?
Have you explored using manual metering for those tricky situations? I can honestly say that I encounter very few exposure problems with the X1 which can't be solved using the manual mode.
Hi, I was using light meters way long ago with my 111f & then M3..the M6 is fine and I’m not looking to improve on the already excellent X1 metering.
It was just a thought to see if anyone had as they will get different readings, did they use both.. It was just an in exercise in knowledge gathering..:cool:
I intend to try using both camera & hand held metering..Just to satisfy myself...
