Filter adapters - air pressure?
swi
I have fitted a Kiwi filter adapter so that I can use 49mm filters etc.
I intend to keep a UV filter fitted permanently on the lens.
My worry is - the adapter and filter are a tight fit. When the lens extends it is like a piston inside the sealed adapter. Where does the air go? Could it blow back towards the sensor?
I was toying with the idea of drilling a small hole in the adapter tube for pressure relief.
Anybody have any data/opinions, please?
When the lens extends it sucks in air, in this case the air that fills the space confined by the adapter and filter. When it retracts this air is released again into the adapter. Even when the camera was sealed air-tight there wouldn’t be any issues. If, on the other hand, the telescoping tubes of the lens where sealed air-tight then the lens could neither extend nor retract; the air pressure inside or outside the lens would prevent that.
Many thanks to both posters above.
Yes, I get it now! It is now obvious that the lens sucks and blows air that is already contained in the adapter tube. But if that air flow is restricted by the adapter, would more air flow through the camera?. Whether this would cause a problem with dust on the sensor depends on how well the sensor is sealed in the camera. If the rear element of the lens is fixed, then there could be an airtight seal there.
I was worried that there might have been a problem with dust, but thinking about it, there would be a worse possible problem with the lens exposed. As the poster above implied, keeping the lens in a filter/adapter enclosure should in fact reduce possible dust problems,
unless, of course, the restriction on air flow at the front causes more air to travel through the body....
Thank you for clarifying my thought processes!
