ziggurat Posted May 11, 2011 Share #1 Posted May 11, 2011 Advertisement (gone after registration) Hello, can anyone give me a heads up on the sharpening regime, or not, for M8 files for Blurb. I am used to applying sharpening for their printing process to Digilux 3 files but obviously the M8 files are a lot sharper to begin with. Any help gratefully received. Regards Johnny Link to post Share on other sites More sharing options...
Advertisement Posted May 11, 2011 Posted May 11, 2011 Hi ziggurat, Take a look here Advice on preparing M8 files for Blurb. I'm sure you'll find what you were looking for!
erl Posted May 12, 2011 Share #2 Posted May 12, 2011 For both M8 and M9 files I find no sharpening is necessary. I regularly print to A2 size with excellent results (technically speaking ) and I have just published a Blurb book at the large landscape size. I made sure the files I created were close to, or larger than the reproduction size. I then allowed Blurb to 'modify' as required. I did use Adobe InDesign 4 to create the book rather than the Blurb software. That gave me more control. Just make sure that the software you use applies the appropriate profiles to the PDF's for Blurb. Link to post Share on other sites More sharing options...
ziggurat Posted May 12, 2011 Author Share #3 Posted May 12, 2011 Thanks Erl That's what I suspected. Saves me wasting money and time on a test. Cheers Johnny Link to post Share on other sites More sharing options...
jedi996sps Posted May 12, 2011 Share #4 Posted May 12, 2011 Hello, can anyone give me a heads up on the sharpening regime, or not, for M8 files for Blurb. I am used to applying sharpening for their printing process to Digilux 3 files but obviously the M8 files are a lot sharper to begin with. Any help gratefully received. Regards Johnny If you pm me in a weeks time i will let you know, as i am awaiting delivery of my first Blurb Book. I uploaded all my images in jpeg format which were resized to suit the Blurb maximum pixel dimension, most of them had sharpening applied using photoshop. Images with people i applied 50% at 0.5radius, others were generally at 100% at 1radius. All images were taken on M8 with in camera settings of colour and sharpness set to medium. Regards Ali Link to post Share on other sites More sharing options...
Alberti Posted May 15, 2011 Share #5 Posted May 15, 2011 In the past few years I have made many Blurb books (tens...). As much as possible I use the standard M8 sharpening settings in Capture One: - version 3.7 standard look (amount 130/radius 1,3, threshold 1,0); - but on portraits I use 'soft look' and go to amount 110/radius 0,8, threshold 1,0. I have even made two page flows on the large square from M8 images. Just a tip: I have noticed that one should not resize several times in the Blurb software - that gives some artifacts; instead I note the enlargement percentage and then import the image again and directly set it to the final size. I noted that only in the large square. These came out great. I get good colours. But myself I am pondering how to check the colour rendering; some mention on this forum that they have used a kind of preview using the Blurb ICC profile, but I don't have any clue how to get that to work in Capture One, i.e. without Photoshop. I find the Kodak books are really a lot better in image quality (sharpness, detail, colour sophistication), but the lack of proper editing tools makes me use Blurb. albert Link to post Share on other sites More sharing options...
