Hyperfocal (X1)
lykaman
x
Provided you have the latest firmware installed you can set the focus so that the right hand side of the DoF bar touches infinity (basically what you would do if there was a DoF scale on the lens).
Surely though Hyperfocal actually focuses
past infinity! I do understand your Input & have used the settings you suggest.
Maybe I should use an old manual lens and
replicate the settings on my X1.
Surely though Hyperfocal actually focuses past infinity!
Whatever that’s supposed to mean … but it doesn’t. Hyperfocal focusing ensures a depth of field extending from half the hyperfocal distance up to infinity.
In manual focus I set F 8 or 11 and than move the wheel untill the right side of the green bar is very near to infinity and check which is than the minimum distance focus. In case I need I turn the wheel in opposite direction untill I need, knowing in this case I can shoot at near distances and the infinity (which sould be the background) will be slightly out of focus.
robert
The V2 firmware makes hyperfocal a snap, simply adjust f/stop and move wheel to desired position, the width of the "green bar" will tell us what is indeed in focus. Very simple I think, isnt it?
CJ
