M9 firmware upgrade in a few days
sblitz
  • Replies 68
  • Created
  • Last Reply
Just ran some tests on the 21/2.8 asph and the correction has improved a lot.
The CV 12/5.6 coded as the 21/2.8 non-asph produces less of a redish/magenta edge on the left side with this firmware than with the former one, so also an improvement.
I'll take that back. The result is unbelievably good! Here a comparison of an 28/2.8 asph Elmarit image at f/16 and with white opaque plastic cover with coding (top) and without coding (bottom), using the new Firmware.
I see a difference between CaptureOne and LR3. The CV 15 (treated as 21/2.8 non-asph), the Elmarit 24 and the Summicron 35 IV are practically clean in LR3 and have a slight magenta corner Top Left in CaptureOne, which is again a compliment for CaptureOne ;)
Sorry! There's a typing error in this message, should be 21/2.8 asph Elmarit.
The 12mm-VC-lens set at >>21/ 2.8 pre asph.<< works beautifully, thx for this hint, great !
Used the manual 16 mm-setting so far with this lens, and this setting still doen´t look alright.
Best
GEORG
_______________________________
Same excellent results with the 15 mm VC-lens. No colourshift, VERY little
vignetting. Just beautiful now.
