Noctilux Filter
roberth
Robert,
Have you tried a Neutral Density filter? It will not get rid of the vignetting, but will allow you to shoot wide open in daylight.
If you really need a center graduated filter, I recall that some older Schneider Super Angulon lenses for large and medium format had this filter available. Try searching the Schneider / B+W page and also check into Cokin, they make just about anything. For the Cokin filters you will need a special adapter, but it might be worth a try.
Good luck,
Jan
thanks Jan, yes I plan on getting a ND of about 5 stops or close to that. I have a 9 stop ND but not in 60mm.
I really want to try using wide open, full daylight but with less vignetting on slide film and see how these project.
I will search out your suggested suppliers.
