tickman Posted April 18, 2011 Share #1 Posted April 18, 2011 Advertisement (gone after registration) I have this lens as someone mentioned to get it for portraits, but due to the tight crop of the lens. Just curious how far back you have to stand to get a good portrait shot with the lens. Playing around. It seems I have to turn the camera 90 degrees for a higher and thinner shot if close to the subject or stand further back to get more in when held in the normal position. I assume if you stand further back. You just blow the image up to make it look closer. Haven't taken any pictures with it yet. Just checking it out. If you have any portrait images. Would like to see what they look like and if you remember. How far back you were when image was taken. Thanks DON Link to post Share on other sites More sharing options...
Advertisement Posted April 18, 2011 Posted April 18, 2011 Hi tickman, Take a look here leica elmar-c 90mm f4 - any portrait images?. I'm sure you'll find what you were looking for!
christer Posted April 18, 2011 Share #2 Posted April 18, 2011 Generally it is a good idea to fill the negative with what is important in the picture. Saves cropping and thus the need to enlarge more than necessary. This probably improves the quality of the print, at least if your prints are larger than an A4 size paper. With portraits, it is generally not desirable to get close enough to fill the negative if you use e.g. a 35 mm lens. If you do so, then the nose will appear unproportionally large on the print. If you use a 90 mm lens this is not a problem. Get close enough to let the face fill the frame if you wish. If you want to include some of the surroundings to add some atmosphere to the picture, step back a bit or use a 50 mm lens. Link to post Share on other sites More sharing options...
christer Posted April 18, 2011 Share #3 Posted April 18, 2011 90 mm full frame, no crop Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/149365-leica-elmar-c-90mm-f4-any-portrait-images/?do=findComment&comment=1648734'>More sharing options...
earleygallery Posted April 18, 2011 Share #4 Posted April 18, 2011 Playing around. It seems I have to turn the camera 90 degrees for a higher and thinner shot if close to the subject Thanks DON You mean 'portrait' format Link to post Share on other sites More sharing options...
tickman Posted April 18, 2011 Author Share #5 Posted April 18, 2011 You mean 'portrait' format An image like Christer's above your post. I have to test out the lens. Right now I only checked through various sized items in my office to see how close and what fits in the frame lines Thanks DON Link to post Share on other sites More sharing options...
tickman Posted April 18, 2011 Author Share #6 Posted April 18, 2011 90 mm full frame, no crop Hi Christer, How close were you to take this image? Thanks DON Link to post Share on other sites More sharing options...
tobey bilek Posted April 18, 2011 Share #7 Posted April 18, 2011 Advertisement (gone after registration) Head and shoulders or business card photos, 5 feet with 90mm on film. Tight face, maybe 4 feet. Waist up. 8 feet. Link to post Share on other sites More sharing options...
tickman Posted April 18, 2011 Author Share #8 Posted April 18, 2011 Head and shoulders or business card photos, 5 feet with 90mm on film. Tight face, maybe 4 feet. Waist up. 8 feet. That helps. Thanks DON Link to post Share on other sites More sharing options...
jgbossert Posted May 27, 2011 Share #9 Posted May 27, 2011 90 mm full frame, no crop Hi Christer, have you taken this picture with the Elmar-C 90/4 ? Best, Gottlieb Link to post Share on other sites More sharing options...
christer Posted May 27, 2011 Share #10 Posted May 27, 2011 Hi Christer, have you taken this picture with the Elmar-C 90/4 ? Best, Gottlieb No, it was taken with an 2,8 90mm Elmarit-M. The purpose was to show what full frame delivers at close distance without cropping. Link to post Share on other sites More sharing options...
jgbossert Posted May 28, 2011 Share #11 Posted May 28, 2011 No, it was taken with an 2,8 90mm Elmarit-M. The purpose was to show what full frame delivers at close distance without cropping. The newer 1990-2008 Elmarit? I ask because I often read it should be a bit too sharp for portraits. But your image does not look too sharp. (My old Elmarit 90 was a little bit too soft wide open for my taste) Link to post Share on other sites More sharing options...
christer Posted May 28, 2011 Share #12 Posted May 28, 2011 The newer 1990-2008 Elmarit? I ask because I often read it should be a bit too sharp for portraits. But your image does not look too sharp.(My old Elmarit 90 was a little bit too soft wide open for my taste) The newer version, i.e. the final version. I guess one could call it so as it is no longer manufactured. I think it is sharp enough, but then I use film and do wet printing. It is only occasionally that I scan, and then only for the internet. I only have a flat bed scanner and I use it to scan from the negatives. My prints (30x40cm) are too large for the scanner I have. I would not judge sharpness from the picture in this thread. A lens too sharp for portraits. I have never come across such a lens. If the negative is too sharp for your taste and you do your own printing, just use the enlarger lens wide open when printing, or use it out of focus, or print through a nylon stocking, or use vaseline. Link to post Share on other sites More sharing options...
pop Posted May 28, 2011 Share #13 Posted May 28, 2011 There's one, taken under somewhat difficult lighting conditions. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/149365-leica-elmar-c-90mm-f4-any-portrait-images/?do=findComment&comment=1685448'>More sharing options...
