Question about IIIc and IIIf rangefinder spot/patch
clat
This is a follow-on to a post I made last week. This is my first adventure into non-M Leicas so I apologize for my lack of knowledge. My earlier question was about the clarity of IIIc and IIIf rangefinders but I did not specifically ask about the rangefinder spot or patch that contains the double image.
My IIIc spot is yellow in tone. When the images are not aligned it has a definite yellow tint and it makes it very easy to see and focus. Good visibility and good contrast. The yellow spot goes away when perfectly focused.
The IIIf rangefinder, while relatively bright, has no visible spot or patch and the double image is barely visible. This lack of visibilty, color, and contrast makes focusing difficult. I want, however, to use this camera.
Can someone help me understand this please? Should the IIIf have the same yellowish spot as the IIIc? Or, is my IIIc special because of some special modification? Should all screw-mount Leicas have the yellowish spot?
Your assistance is greatly appreciated.
I confirm : haven't the breadth of models of JC... ;) but a IIIc and a IIIf : IIIc tends to yellow, IIIf no... but the 2 images to align are anyway well clear... can be that your IIIf needs simply a good C(LA) of the RF... if the RF-projected image is "dirty/foggy" an OKARO can result of little improvement...
Another possibility is that a handy mechanic installed a thin yellow gelatin filter into the optical path inside the rangefinder housing. I have seen this done many years ago..... As I say though, just a possibilty.....
Best,
Jan
Curiosity forced me to check my thread mount bodies.... I checked models II, III, IIIa, IIIb, IIIc (wartime and post-war) and IIIf - none have yellow rangefinder spots. So - if there are bodies with that 'feature', I would attribute it to an aftermarket built-in filter in the RF internal optical path or, some of the optical components yellowing with age.
Best,
Jan
I think you've started something here. I've checked my II (conversion from IA in 1932) which has a yellow surround but clear spot; my sharkskin IIIc which is clear; and my IIIf black dial, also clear. This may add to Jan's thought that some components yellow with age.
