click Posted March 27, 2011 Share #1 Posted March 27, 2011 Advertisement (gone after registration) Hello, What sizes do Leitz easels come in? I'd be interested in a 16x12 version? Was this size made? I've seen 12x10 and 8x10 versions. Thank you, Click Link to post Share on other sites More sharing options...
Advertisement Posted March 27, 2011 Posted March 27, 2011 Hi click, Take a look here Leitz Leica Easel . I'm sure you'll find what you were looking for!
ho_co Posted March 27, 2011 Share #2 Posted March 27, 2011 IIRC, I've seen 8 x 10 and 11 x 14 sizes. I don't think any were larger. Link to post Share on other sites More sharing options...
click Posted March 27, 2011 Author Share #3 Posted March 27, 2011 Ollinger's Guide to Photographic Enlargers: Leitz Enlargers I just found this link where the author talks about a 12x16 easel and it seems logical since this is a common european paper size. Link to post Share on other sites More sharing options...
pico Posted March 27, 2011 Share #4 Posted March 27, 2011 Hello, What sizes do Leitz easels come in? I'd be interested in a 16x12 version? Was this size made? I've seen 12x10 and 8x10 versions. Yes, there was a rare Valoy intended for extreme enlargements. My 16x20 easel just fits properly. It an an extra long column, and a special cooling bonnet in the light housing to allow big watt bulbs. I have one. Never seen another. Link to post Share on other sites More sharing options...
Michael Hiles Posted March 28, 2011 Share #5 Posted March 28, 2011 What sizes do Leitz easels come in? I'd be interested in a 16x12 version? Was this size made? I've seen 12x10 and 8x10 versions. Click The only one I have seen is 8x10, which I have. I like the locking feature. I also have a Saunders 11x14 border-less easel that is exactly the same thickness as the Leitz unit - which makes it usable with my autofocus Focomat Ic without further adjustments. The also make/made a 16x20 border-less unit Link to post Share on other sites More sharing options...
ho_co Posted March 28, 2011 Share #6 Posted March 28, 2011 The larger easel I saw may indeed have been 12 x 16. In the US, the more common paper size is 11 x 14, so I may simply not have noticed the difference. As you know, the Focomat Ic was delivered with a pin which fit into either of two different sets of holes in the upright. The lower set was for enlarging on the baseboard; the higher set was for use with the smaller Leitz easel. The larger of the two easels was thicker, and was delivered with a spacing ring to be placed atop the pin when it was in the upper set of holes, to adjust the enlarger height to accommodate the easel. I can't understand why the link you offer shows that the Ic was focused by helicoid. Yes, there was a helicoid for initial adjustment of the lens, but the autofocus mechanism was via cam, which extended the bellows. Same with the Focomat V-35, where the link says the focusing type is unknown. Again, there's an adjustable helicoid to tune the lens and enlarger, but as an autofocus enlarger, its focus was cam-driven. No bellows in this case, but a collapsing tube mechanism. The larger easel was really more suitable for use with the Focomat IIc, simply because of the size of the Ic's baseboard. Link to post Share on other sites More sharing options...
