Do you hear any sound when turn your M8 around?
tuanvo1982
x
Was a lens attached when you did this? On some lenses, the aperture blades have been known to make a slight rattling sound when shaken. Another possibility could be the strap fittings. (Or it could be all of your Imp's china falling out of his dresser as you turn his home upside-down.)
I seem to recall that the camera has a mechanical orientation sensor (Mark? ) which may-just- produce a minisound.
I think it has a mechanical orientation sensor. Actually, it is mini-sound, if you keep body nearly your ears then turn it around or shake it, I am sure that we can hear somethings. :)
I already take all stuff off (lens, strap even battery and SD :)) but I still hear that.
I think Leica has its HEART hehe :))
Yes, it's the orientation sensor on the DSP board. This has a V shaped groove in it with a small ball bearing rolling in it and tells the camera whether it is horizontal, left side down or right side down. The ball bearing changes the inductance of a coil from which the camera can determine the orientation.
[ATTACH]248833[/ATTACH]
Yeahhhhhh, I got it.
