Instalation Pblm - Silver Efex Pro
I have acquired and installed Silver Efex Pro v1 to work with PS Elements v5.
During installation I chose the PlugIns folder as the destination. But when the installation process tries to find an application (i.e. PS Elements) nothing shows up in the table, and when I open Elements, the SFP does not appear anywhere. I was expecting it to appear as one of the Filters - but nothing.
Does anyone know of an obvious fix, or something I am evidently doing wrong?
All help and advice is most welcome and thanked in advance.
In Lightroom, you select your photo, go to the toolbar across the top, select "photo", scroll down to "edit in" and select silver efex pro2, whereupon lightroom shows in the upper left hand corner" preparing file for...and it opens a small window for you to handle the edited photo (stack with original etc) then after you select it opens silver efex in a new window. Perhaps PSE5 will have some similarities?
kaeth
Thanks, all.
I called the appropriate number and was told that Silver Efex Pro is not compatible with PE versions < 6.
Interesting, because about 18 months ago I tried the time-limited trial version, which worked fine with PE v2!!?? I post this on the off chance it may be useful to someone.
Anyway, it is likely time to upgrade to PE9, since I (legitimately) did not pay for for either of my current versions.
Thanks again.
