Easter eggs in M8 firmware
steich
Hi,
when trying the "highlight trick" mentioned in jaaps posting
http://www.leica-camera-user.com/digital-forum/14769-little-highlight-trick-m8.html
I tried to do as he said- but after clicking on the arrows a few times suddenly my camera showed a black screen with a picture´s file number on it! When I turned the wheel to see multiple pictures, I see that the picture with the certain file number has indeed multiplied....could that be some kind of "copy" function?????????
What leads me to the question: Has anybody found other "easter eggs" or hidden features in the M8 firmware? Any "smart" key combinations?
Regards
Stefan
If there're any Easter Egg code in there, it is probably *not* tested because it is not a generally released code.
Please don't complain to Leica if your M8 goes into a "jammed" state.
A neat feature to check a series of pictures for sharpness is to press play, enlarge, then keep play pressed down and use the thumbwheel arrow button, this will scroll to the next picture using the current enlargement setting. Neat.
I don't know if this is generally known but I find the histogram setting in the main display disappears after review, so you can press info and with the info button constantly pressed you can scroll to the main photograph.
Love the M8, trying to improve my technique.
