jpattison Posted January 18, 2011 Share #1 Posted January 18, 2011 Advertisement (gone after registration) Hi, I have a FARUX panoramic head with 1/4 inch male and female thread. Marked Ernst Leitz Wetzlar, Germany. It is fitted with the FAXIS 9cm horizontal/vertical marked ring. with 1 - 17 for horizontal, 1 - 25 for vertical. How do you remove the FAXIS? I don't have any other ring, but am curious! photo to follow. Thanks, John Link to post Share on other sites More sharing options...
Advertisement Posted January 18, 2011 Posted January 18, 2011 Hi jpattison, Take a look here FARUX with FAXIS. I'm sure you'll find what you were looking for!
ismon Posted January 18, 2011 Share #2 Posted January 18, 2011 John, Simply rotate the FAXIS to the #1 position. You will see a little notch now under the indicator tab. Pull up on the FAXIS ring. To replace the ring, just line up the #1 notch with the spring tab and push the ring down onto the FARUX. Link to post Share on other sites More sharing options...
jpattison Posted January 18, 2011 Author Share #3 Posted January 18, 2011 Thanks, it was a little stiff, but it came off OK. John Link to post Share on other sites More sharing options...
