sending high quality files, setting dpi?
Hello...I need to send a highest possible quality photo file which will be printed at A2 size.
The people have just stated RGB 300 dpi..
I have read that you can change dpi on export from Lightroom but i cannot see how this is done or any mention of dpi in lr export. I don't use ps.
I would be very grateful for some help.
Thankyou..
Lucy
Hello...I need to send a highest possible quality photo file which will be printed at A2 size. The people have just stated RGB 300 dpi. I have read that you can change dpi on export from Lightroom but I cannot see how this is done or any mention of dpi in Lightroom export. I don't use Photoshop. I would be very grateful for some help.
A2 size is 42 × 59.4 cm, or 16.5 × 23.4 inches. At 300 ppi, that's 4,960 × 7,015 pixels. To arrive at this size, an M8 image needs to be upsized by a linear factor of 1.78×; an M9 image needs to be upsized by a linear factor of 1.35×. With proper processing, M8 and M9 images will take this (moderate) degree of upsizing just graciously.
However, most likely the persons asking for '300 dpi' files simply have no idea what they actually are talking about. Usually they just thoughtlessly repeat a buzzword they once learned without really understanding what it means. In most cases, they'll be happy if you just deliver files with the EXIF ppi field set to '300,' regardless what the actual pixel size really is.
Oops ... I guess it's purely academic by now, but I'm afraid I got the linear magnification factors wrong in my previous post. Forgot to take the different aspect ratios of the Leica cameras' image format and the A2 format into consideration. So just for the records—the factors really are 1.89× for the M8 and 1.43× for the M9.
By the way, the Leica S2 would provide A2 size at 300 ppi natively, i. e. without upsizing. But in the final A2-sized print, you'd be hard-pressed to note any visible difference between an S2 image at native size and an M9 image that got upsized properly. I'm not saying there were no differences at all ... but at A2 size or less, they'll be really subtle. The size advantage of the S2 (or similar digital medium-format cameras) will become obvious for most people only at print sizes significantly larger than A2. So—asking for 300 ppi file to print at A2 size is a rather foolish thing. But as I said, those people usually have disconcertingly low knowledge about their own business ... :(
Sending just your camera's full-size files (w/ or w/o some post-processing applied, as you think fit) should be just fine. And don't worry about the RGB colour space; images out of the camera or out of Lightroom will always be properly tagged so both sRGB and Adobe RGB (or whatever) should be equally fine.
Oop
Provided the receiving side reads the tags properly...Which considering the 300 DPI request makes a 50-50-chance ;)
