jc_braconi Posted December 4, 2010 Share #1 Posted December 4, 2010 Advertisement (gone after registration) The Leica M6 production commenced in 1984 and ended in 1999 with a total production of 132454 issues 75453 in black chrome finish, 51725 in satin silver chrome and 5276 specials editions. The M6 offers through the lens metering in a normal sized M body. A fixed silicon diode points to a white spot at the center of the image area on the front blind. The electronics are housed in the space usually used for the delayed action mechanism and the battery case is in front of the camera body. A disc on the hinged flap at the back is used to set the film speed for the metering and three gold contacts inside the back complete the circuit when the flap is closed after loading the film. Metering is switched on when slight pressure is applied to the release button. Correct exposure is indicated by the even illumination of two triangular shaped diodes in the viewfinder. Exposure adjusted by either the diaphragm ring or the shutter speed dial : either turning in the direction indicated by the illuminated diodes until both diodes are evenly lit. Electrical power is only required for light measurement, in all other optical and mechanical respects the M6 is identical to the M4-P. The M6 was manufactured in Wetzlar and the top plate wears the inscription “Ernst Leitz Wetzlar GmbH” Normal finish is black chrome , but a silver version was introduced in 1986. Not less than 21 specials and commemorative editions, were reported. For illustrations here a M6 black from the early issues wearing the Leitz engraving in the red logo, “MADE IN GERMANY” is hot stamped, in vertical, in the vulcanite, on the rear right side of the camera body. Near is a satin chrome issue for the lately issues wearing the Leica engraving in the red logo. Both are fitted by a Summilux 1.4/50mm lens and are sitting in their genuine boxes. Included some M6 instructions for use leaflets in both German and French editions. Link to post Share on other sites More sharing options...
Advertisement Posted December 4, 2010 Posted December 4, 2010 Hi jc_braconi, Take a look here A little...52. I'm sure you'll find what you were looking for!
luigi bertolotti Posted December 4, 2010 Share #2 Posted December 4, 2010 Nice duo... but Ihad preferred the chrome with a chrome lens... Link to post Share on other sites More sharing options...
tobey bilek Posted December 5, 2010 Share #3 Posted December 5, 2010 Looks like my pair. After mixing up color and B&W in two chrome bodies, I started buying pairs. Link to post Share on other sites More sharing options...
Robert J Posted December 5, 2010 Share #4 Posted December 5, 2010 I have the early version M6,without the plastic wear protectors above the neckstrap eyelets.I have also used chrome lenses on it and on my black chrome M5.Correct me if I"m wrong but I believe leitz/leica did not make chrome lenses during the early years of M6 production. Link to post Share on other sites More sharing options...
Guest Ron (Netherlands) Posted December 5, 2010 Share #5 Posted December 5, 2010 Correct me if I"m wrong but I believe leitz/leica did not make chrome lenses during the early years of M6 production. 35mm summicron (type IV) was also in chrome available Link to post Share on other sites More sharing options...
jc_braconi Posted December 5, 2010 Author Share #6 Posted December 5, 2010 Nice duo... but Ihad preferred the chrome with a chrome lens... I agree with you Luigi, but the one I can use was made after this production, ie the Elmar-M 2.8/50mm, what we can see on the front ring is the different position of the lettering between the 2 Summilux; same difference on the two Summicron 2/35mm ASPH. on the M6TTL. Link to post Share on other sites More sharing options...
