Classified Section - Registration
paragon
Hi everyone - a little help please,
Do I have to register again to use the Classified section - when I move from this forum, (logged on as a member), I become a guest on the Classified section and that section will not accept my user name and password to "log on"
Cheers
Not sure but I thought your user name and password got carried over. I do know that I need to log in when I go there but I do not remember if I registered again using the same user name and password at the classified section. I don't think I did.
I suggest the straight forward step of contacting Forum Management regarding this.
I'm fairly sure none of us random forum membership folks can determinatively assist you. Commiseration and Advice we certainly can give, tho!
Hope it works out for you.
R.
Cheers
R.
Thanks - I've just got a used M8 - so I'm getting used to Leica (digital) "quirks"
R.
How do I contact Forum Management - when I try to register on the classified section it says that I am already registered although it says that I am a Guest in the top section
I would like to contact a seller
Thanks
Hello Paragon - you probably did what Tech Support calls 'Fat-Fingering' during your first failed login attempt. That is committed a random typographical error keying in your id and password. It's rumored that the record for consecutive failed logins due to Fat-Fingering Syndrome is 37, but I might just be committing hyperbole!
By The Way:
ive n ever comm itt ed a typ o inm y li fe. :)
Hee Hee
R. in Michigan
just managed to sort out the problem -I have to log in again to get access to the Classified Section - first time it did not accept my log in - the second time it did
