S2 Remote Cable release
tag62
Does anybody know if leica or any other company has come up with a remote cable release for the s2. I mean 20 meters plus. ie Infra Red or something to that effect. I have a Strobies Interfit that works up to 100m for a Nikon D3x I have that works fantastic.
Help would be much appreciated.
tag62
I'm really curious what use you have for such a long release? I thing you are going to have to hack a short release cut in half and splice into an infrared transceiver.
Eventually there was to be a wifi adaptor that should do the work for you, but no mention of it in recent times.
Thanks for the suggestion. I will look into the possibility of doing so.If it is possible that will be great
Essentially, I use the cable release while I am out photographing. My work often includes myself in it. I usually prefer to work alone. Actually I dont need more than about 25m but the only one that has worked well in the past is the Strobies. Works well even in direct sunlight. Thank you very much for the suggestion.
  • 3 weeks later...
