Any difference between viewfinder brightness R8 / R9
leicanewbie
The biggest diffeence between the two is the exceptionally light-weight top plate. The next biggest change is the number 9 instead of the number 8. There are other minor changes, but none with the excellent viewfinder.
They are the same viewfinder and in my opinion bouthe are excelent.;)
The big changes are the top cover made in magnesiun and some improvements whit the flash and metering.
You say your R8 goes to repair once more:( what is the problem of your camera?:confused:
Best,
Rui,
The camera was working fine for about a month, and now the DOF mechanism doesn't
spring back. Normally it does so that you can adjust the aperture while you look through
the lens. So now, if I stop it down to f/16 or f/22, I can barely see out the lens because
the DOF preview is stuck that way.
Hopefully it'll be a quick fix.
Milan
leicanewbie ,
In the inside it was one spring so when you active the DOF this spring makes the mecanism came back to original position when you leave then.
Maybe this spring came loose or broken.
Pay attention to the rubber cover near the DOF botton because thsi cover sometimes peel of and stuck the DOF botton!!
I clean mine when I notice this problem and no problem whit the DOF botton.
When your camera came back pay attention to this.
Best,
