D-Lux 5 zoom question
ho_co
The lens of the D-Lux 4 has the interesting characteristic that it is physically longest when at widest angle, and least extended when at its maximum focal length.
How does the lens of the D-Lux 5 behave when shuttling between its shortest and longest focal lengths?
Thanks!
The LX is the longest at it's 90mm setting. Shortest at the 50mm and slightly longer @ 35mm. @ 70mm it is longer then at the 50 & 35. Then it gets longer as you go to 28 and longer still @ 24 but not as long as it is at 90mm.
So I can see why with the DL4/LX3 the lens is the longest at the 24mm mark. Since that camera doesn't go beyond 60mm
Thanks, Ed and Pete! :)
Sounds as if the WA adapter for the D-Lux 4 couldn't be used safely with the D-Lux 5.
The D-Lux 4's adapter ring has a length of 29.5 mm, and the WA adapter just barely clears the front of the lens.
(The WA adapter for the D-Lux 4 isn't much of a piece of glass, and I didn't want to be tempted to buy another one that probably isn't any better. :( )
You guys are gradually getting me to consider this new beastie. (Sigh.)
Thanks!
Howard, while you have received an answer, while slightly off-topic, may I add that the ability to memorise the zoom setting is new, I believe, on the D-Lux 5, and a welcome improvement.
Yes when you set it to a mm and turn the camera off the next time you turn it on that zoom mm setting is retained. Very nice.
Interesting to hear, Griff.
I posted some comparisons at http://www.l-camera-forum.com/leica-forum/digital-forum/76883-d-lux-4-wa-conversion-lens.html.
[Malcolm Garvin ("macgarvin") may have also done so, though I'm not sure.]
I'd like to compare your results. Maybe you could post a similar comparison?
I know the WA lens adapter for the Digilux 2 was supposed to be quite good optically, so maybe I just got a bad sample?
... the ability to memorise the zoom setting is new, I believe, on the D-Lux 5....
Yes when you set it to a mm and turn the camera off the next time you turn it on that zoom mm setting is retained....
With the D-Lux 4 set to return to the previous zoom setting at turn-on (firmware 2.2), we got as (IMHO rather annoying) lagniappe the message "THE ZOOM WILL NOW RETURN TO THE SAME POSITION TO [sic] WHEN THE UNIT WAS TURNED OFF."
Has Panasonic deleted the heads-up on the new camera, or at least corrected the grammar? :p
... who the hell needs this in ONE lens ?
Georg, that was my feeling as well when people started working out ways to obtain the same with the D-Lux 4 (for example, http://www.l-camera-forum.com/leica-forum/digital-forum/79843-d-lux-4-setting-focal-length.html).
When I asked on the forum why the heck they thought setting a specific equivalent focal length would be helpful, I was surprised to get back serious and well considered answers.
Unfortunately, I can't recall any of them. :cool::confused::cool:
