Can I develop Neopan 1600 with ID-11?
decay2000
x
ID-11 is virtually the same formula as D76 and is a very versatile developer.
Use 9 minutes at 20C for ID-11 1+1 with NP1600. I'd use 10 secs agitation pr minute. See also the Massive Dev Chart http://www.digitaltruth.com/chart/search_text.php?Film=Neopan+1600
Suggest you use Google to check out other peoples experiences.
Carl
Hi
ID11 (and D76) can be used as stock or 1:1 ... 1:3 the stock does a finer grain the 1:3 has better edge sharpness.
Depends what you are after.
I'd use D76 times without worrying and temperature is as critical.
Noel
