efix Posted September 15, 2010 Share #1 Posted September 15, 2010 Advertisement (gone after registration) Dear fellow Leicanians, I have just received the UV/IR filter for my M-Rokkor 28/2.8, and I feel I need to code it. I'm not sure whether I'm seeing cyan corners, but in any way, I think coding would only be beneficial. Now my question is as which lens to code it: Elmarit 28/2.8 V1, V2, V3, V4 or ASPH.? What is the experience of those owning and using the lens on the M8? Also, which coding system should I get? Or should I do it all by myself? Should I use a permanent marker or paint? Questions, questions! Please help! Link to post Share on other sites More sharing options...
Advertisement Posted September 15, 2010 Posted September 15, 2010 Hi efix, Take a look here M-Rokkor 28/2.8 - as what to code, and how?. I'm sure you'll find what you were looking for!
k.a Posted September 15, 2010 Share #2 Posted September 15, 2010 try pre-asph 28mm elmarit, don't think they are coded serparate. i would start with using a marker penn, if the results are good, make it more permanent Link to post Share on other sites More sharing options...
