ptarmigan Posted July 28, 2010 Share #21 Posted July 28, 2010 Advertisement (gone after registration) Ian, a white luminance value of 120 cd/m2 is normal for a LCD screen. As I said before, the black luminance is extremely important. You must have it at 0.34731% of the white luminance (0.42 cd/m2 for a white luminance of 120 cd/m2). Setting in Adobe RGB colour space white luminance at 80 cd/m2 is too low to get 0.42 cd/m2 (*). You must be missing black levels For instance, using this online test Monitor Calibration Tests: Black Point I can start seeing black levels starting at RGB=(1,1,1) Maybe this help: LCD monitor test images (*) Just for information: In my monitor, to get a black luminance of 0.42 cd/m2 at a while luminance of 120.0 cd/m2, I had to reduce the contrast control at 8 and the brightness control at 53 while RGB channels are: red=54, green=37, bue=37 Interesting stuff! Using the black point test I can definitely see changes from 2,2,2, not 100% sure if I can see 1.1.1 but then I cannot remove all extraneous light sources, I have a window to the left/behind the monitor and another at 90º to the right. I have pulled down both blinds but they are not light-safe. I might have another go at re-caliberation this evening. I have an EyeOne and use ColorEye Display Pro software. Link to post Share on other sites More sharing options...
Advertisement Posted July 28, 2010 Posted July 28, 2010 Hi ptarmigan, Take a look here LCD Monitor Calibration: Lightroom 3 & CaptureOne 5 Pro . I'm sure you'll find what you were looking for!
